I have implemented a form action SPI to create a custom registration flow, and I’m creating a ProviderConfigProperty called ‘policystatus’ which is of type MULTIVALUED_STRING_TYPE. When I build the jar, this input does not appear in the Keycloak admin console.
Colleagues exactly with the same version of Keycloak 24.01, using the exact same jar and having the same settings, it runs fine on their laptops and the input appears perfectly. Do you know what might be wrong?"
