I’m using keycloak-js
to integrate in my front end project (React). It’s working pretty well, but when I have 2 or more tabs of my system, only the last one is able to refresh token, the others get error 400 and are redirected to logout confirmation page.
I found some similar case on the internet, but I couldn’t find any solution yet.
I’m using keycloak-js@21.0.1 and my init config are like this:
onLoad: 'check-sso',
silentCheckSsoRedirectUri: window.location.origin + '/silent-check-sso.html',
Is there anyone fixing the same issue? how can I fix this?
