NoSuchMethodError on ValidationContext.getHttpRequest()
I have implemented a custom form action, deployed, chosen as a custom step in Registration, and attempted to go through the register flow with this as the first step.
I built this by referencing/copying how other Keycloak form actions like RegistrationPassword do it. However, I am getting a NoSuchMethodError on ValidationContext.getHttpRequest().
Specific code:
@Override
    public void validate(ValidationContext context) {
        MultivaluedMap<String, String> formData = context.getHttpRequest().getDecodedFormParameters();
Full code:
package com.github.thomasdarimont.keycloak.registration;
import lombok.extern.jbosslog.JBossLog;
import org.keycloak.Config;
import org.keycloak.authentication.FormAction;
import org.keycloak.authentication.FormActionFactory;
import org.keycloak.authentication.FormContext;
import org.keycloak.authentication.ValidationContext;
import org.keycloak.events.Details;
import org.keycloak.events.Errors;
import org.keycloak.forms.login.LoginFormsProvider;
import org.keycloak.models.AuthenticationExecutionModel;
import org.keycloak.models.KeycloakSession;
import org.keycloak.models.KeycloakSessionFactory;
import org.keycloak.models.RealmModel;
import org.keycloak.models.UserModel;
import org.keycloak.models.utils.FormMessage;
import org.keycloak.provider.ProviderConfigProperty;
import javax.ws.rs.core.MultivaluedMap;
import java.util.HashMap;
import java.util.List;
import java.util.Map;
@JBossLog
public class DuplicatePhoneDobRegister implements FormAction, FormActionFactory {
    private static final String PROVIDER_ID = "duplicate-phone-dob-registration";
    private static final String DATE_OF_BIRTH = "dateOfBirth";
    private static final String PHONE_NUMBER = "phoneNumber";
    private static final String DATE_OF_BIRTH_REQUIRED_MESSAGE = "dateOfBirthRequired";
    private static final String PHONE_NUMBER_REQUIRED_MESSAGE = "phoneNumberRequired";
    @Override
    public String getHelpText() {
        return "Registration step to check for duplicate users by phone number and date of birth.";
    @Override
    public List<ProviderConfigProperty> getConfigProperties() {
        return null;
    @Override
        log.info("formData: " + formData.toString());
        context.getEvent().detail(Details.REGISTER_METHOD, "form");
        // validate user input
        KeycloakSession session = context.getSession();
        RealmModel realm = session.getContext().getRealm();
        log.info("contain DOB? " + formData.containsKey(DATE_OF_BIRTH));
        if (!formData.containsKey(DATE_OF_BIRTH)) {
            context.error(Errors.INVALID_REGISTRATION);
            formData.remove(DATE_OF_BIRTH);
            List<FormMessage> errors = List.of(new FormMessage(DATE_OF_BIRTH, DATE_OF_BIRTH_REQUIRED_MESSAGE));
            context.validationError(formData, errors);
            return;
        if (!formData.containsKey(PHONE_NUMBER)) {
            formData.remove(PHONE_NUMBER);
            List<FormMessage> errors = List.of(new FormMessage(DATE_OF_BIRTH, PHONE_NUMBER_REQUIRED_MESSAGE));
            return;
        Map<String, String> params = new HashMap<>();
        params.put(DATE_OF_BIRTH, formData.getFirst(DATE_OF_BIRTH));
        params.put(PHONE_NUMBER, formData.getFirst(PHONE_NUMBER));
        boolean otherUserExists = session.users().searchForUserStream(realm, params).findAny().isPresent();
        log.info("otherUserExists: " + otherUserExists);
        if (otherUserExists) {
            List<FormMessage> errors = List.of(new FormMessage(FormMessage.GLOBAL, "Your account couldn't be " +
                "created. If you've already created an account, please log in or reset your password."));
            return;
        context.success();
    @Override
    public void success(FormContext context) {
        // handle successful form submission
        log.info("Custom Duplicate Phone DOB Register Form Action success!");
    @Override
    public void buildPage(FormContext context, LoginFormsProvider form) {
        // render user input form
    @Override
    public boolean requiresUser() {
        return false;
    @Override
    public boolean configuredFor(KeycloakSession session, RealmModel realm, UserModel user) {
        return true;
    @Override
    public void setRequiredActions(KeycloakSession session, RealmModel realm, UserModel user) {
        // add required actions if required
    @Override
    public boolean isUserSetupAllowed() {
        return false;
    @Override
    public void close() {
        // NOOP
    @Override
    public String getDisplayType() {
        return "Duplicate Phone DOB Check";
    @Override
    public String getReferenceCategory() {
        return null;
    @Override
    public boolean isConfigurable() {
        return false;
    private static AuthenticationExecutionModel.Requirement[] REQUIREMENT_CHOICES = {
        AuthenticationExecutionModel.Requirement.REQUIRED,
        AuthenticationExecutionModel.Requirement.DISABLED
    @Override
    public AuthenticationExecutionModel.Requirement[] getRequirementChoices() {
        return REQUIREMENT_CHOICES;
    @Override
    public FormAction create(KeycloakSession session) {
        return this;
    @Override
    public void init(Config.Scope config) {
        // NOOP
    @Override
    public void postInit(KeycloakSessionFactory factory) {
        // NOOP
    @Override
    public String getId() {
        return PROVIDER_ID;
Any help would be appreciated.
Same error here, any help?
Not sure, but this might have something to do with the recent change in the Keycloak codebase from returning org.jboss.resteasy.spi.HttpRequest (pre v21) to returning a org.keycloak.http.HttpRequest (v21+). Make sure you’re both compiling against and running the same version of Keycloak to avoid this kind of error.
New javadoc for that method:
https://www.keycloak.org/docs-api/21.0.1/javadocs/org/keycloak/authentication/FormContext.html#getHttpRequest()
Yes that worked! Did not realize the newest version changed this.
@tbattisti I changed the Keycloak version build target from my 20.0.3 to 21.0.1, rebuild, and deployed. Now it works.
