17:07:25,060 INFO [org.jboss.modules] (main) JBoss Modules version 1.10.0.Final
17:07:25,939 INFO [org.jboss.msc] (main) JBoss MSC version 1.4.11.Final
17:07:25,994 INFO [org.jboss.threads] (main) JBoss Threads version 2.3.3.Final
17:07:26,428 INFO [org.jboss.as] (MSC service thread 1-4) WFLYSRV0049: Keycloak 10.0.1 (WildFly Core 11.1.1.Final) starting
17:07:28,271 INFO [org.wildfly.security] (ServerService Thread Pool – 20) ELY00001: WildFly Elytron version 1.11.4.Final
17:07:28,882 INFO [org.jboss.as.controller] (Controller Boot Thread) OPVDX002: Failed to pretty print validation error: null
17:07:28,891 ERROR [org.jboss.as.server] (Controller Boot Thread) WFLYSRV0055: Caught exception during boot: org.jboss.as.controller.persistence.ConfigurationPersistenceException: WFLYCTL0085: Failed to parse configuration
at org.jboss.as.controller.persistence.XmlConfigurationPersister.load(XmlConfigurationPersister.java:143)
at org.jboss.as.server.ServerService.boot(ServerService.java:392)
at org.jboss.as.controller.AbstractControllerService$1.run(AbstractControllerService.java:416)
Caused by: javax.xml.stream.XMLStreamException: com.ctc.wstx.exc.WstxParsingException: Received non-all-whitespace CHARACTERS or CDATA event in nextTag().
at [row,col {unknown-source}]: [142,21]
at org.jboss.as.connector.subsystems.datasources.DataSourcesExtension$DataSourceSubsystemParser.readElement(DataSourcesExtension.java:650)
at org.jboss.as.connector.subsystems.datasources.DataSourcesExtension$DataSourceSubsystemParser.readElement(DataSourcesExtension.java:204)
at org.jboss.staxmapper.XMLMapperImpl.processNested(XMLMapperImpl.java:122)
at org.jboss.staxmapper.XMLExtendedStreamReaderImpl.handleAny(XMLExtendedStreamReaderImpl.java:69)
at org.jboss.as.server.parsing.StandaloneXml_10.parseServerProfile(StandaloneXml_10.java:587)
at org.jboss.as.server.parsing.StandaloneXml_10.readServerElement(StandaloneXml_10.java:222)
at org.jboss.as.server.parsing.StandaloneXml_10.readElement(StandaloneXml_10.java:119)
at org.jboss.as.server.parsing.StandaloneXml.readElement(StandaloneXml.java:126)
at org.jboss.as.server.parsing.StandaloneXml.readElement(StandaloneXml.java:52)
at org.jboss.staxmapper.XMLMapperImpl.parseDocument(XMLMapperImpl.java:76)
at org.jboss.as.controller.persistence.XmlConfigurationPersister.load(XmlConfigurationPersister.java:126)
… 3 more
Caused by: com.ctc.wstx.exc.WstxParsingException: Received non-all-whitespace CHARACTERS or CDATA event in nextTag().
at com.ctc.wstx.sr.StreamScanner.constructWfcException(StreamScanner.java:634)
at com.ctc.wstx.sr.StreamScanner.throwParseError(StreamScanner.java:504)
at com.ctc.wstx.sr.StreamScanner.throwParseError(StreamScanner.java:488)
at com.ctc.wstx.sr.BasicStreamReader.nextTag(BasicStreamReader.java:1223)
at org.jboss.staxmapper.XMLExtendedStreamReaderImpl.nextTag(XMLExtendedStreamReaderImpl.java:152)
at org.jboss.as.connector.subsystems.datasources.DsParser.parseDataSource_4_0(DsParser.java:1927)
at org.jboss.as.connector.subsystems.datasources.DsParser.parseDataSources(DsParser.java:229)
at org.jboss.as.connector.subsystems.datasources.DsParser.parse(DsParser.java:189)
at org.jboss.as.connector.subsystems.datasources.DataSourcesExtension$DataSourceSubsystemParser.readElement(DataSourcesExtension.java:643)
… 14 more
17:07:28,898 FATAL [org.jboss.as.server] (Controller Boot Thread) WFLYSRV0056: Server boot has failed in an unrecoverable manner; exiting. See previous messages for details.
17:07:28,965 INFO [org.jboss.as] (MSC service thread 1-3) WFLYSRV0050: Keycloak 10.0.1 (WildFly Core 11.1.1.Final) stopped in 20ms
Press any key to continue . . .
From your stack-trace: Caused by: com.ctc.wstx.exc.WstxParsingException: Received non-all-whitespace CHARACTERS or CDATA event in nextTag().
It’s not keycloak problem, you might copied the those configurations from document-page, which is contains non white-space albeit invisible characters. So its cause jboss to read XML configuration.
Better solution, by duplicate existing configuration (h2 db) and modify it to postgresql.
After change the configuration when i start the standalone.bat then we are getting the bellow error logs.
First of all, you say you’re switching to PostgreSQL but are configuring a mysql driver in your module?
Second, it seems that your module xml is invalid on first glance, where is the closing module tag at the end?
Remove also all whitespaces at the end in those files, maybe you copy pasted some wrong things
The Keycloak documentation clearly states that you need the following in your module.xml
Also check your module.xml and standalone-ha.xml file for non white space albeit invisible characters.
Consult your IDE on how to view these or remove all white spaces all together in the file
When reading your error log it says at [row,col {unknown-source}]: [142,21], so it seems to be your standalone.xml file, take a look in your editor what’s on that row and column
You could copy the <subsystem xmlns="urn:jboss:domain:datasources:5.0"> block and replace all variable placeholders or keep them as is and use environment variables
Also check if it’s needed to add the postgreSQL module, mine in the Docker container is located under /opt/jboss/keycloak/modules/system/layers/base/org/postgresql/jdbc/main and it’s already present
Those <200b> characters in the file I’ve shown in the screenshots can’t be there. Keycloak will fail while parsing the configuration file because these are there. It’s like parsing malformed JSON but in this case it’s XML.
These characters can popup from copy pasting stuff from websites and so on. It’s better to use the plugin I’ve mentioned or use an editor than can view these characters when you experience similar problems.
The error itself says it all
