I have some functional tests that use the Keycloak docker image to run against. Intermittently when authenticating with Keycloak, the tests will fail. Sometimes when this occurs, I will see the following NPE (other times, my test fails to capture trace from the container):
02:33:25,091 ERROR [org.keycloak.services.error.KeycloakErrorHandler] (default task-2) Uncaught server error: java.lang.NullPointerException
at org.keycloak.keycloak-services@16.1.1//org.keycloak.services.util.AuthenticationFlowURLHelper.getLastExecutionUrl(AuthenticationFlowURLHelper.java:92)
at org.keycloak.keycloak-services@16.1.1//org.keycloak.services.util.BrowserHistoryHelper$JavascriptHistoryReplace.saveResponseAndRedirect(BrowserHistoryHelper.java:93)
at org.keycloak.keycloak-services@16.1.1//org.keycloak.services.resources.LoginActionsService.processFlow(LoginActionsService.java:324)
at org.keycloak.keycloak-services@16.1.1//org.keycloak.services.resources.LoginActionsService.processAuthentication(LoginActionsService.java:283)
at org.keycloak.keycloak-services@16.1.1//org.keycloak.services.resources.LoginActionsService.authenticate(LoginActionsService.java:267)
at org.keycloak.keycloak-services@16.1.1//org.keycloak.services.resources.LoginActionsService.authenticateForm(LoginActionsService.java:340)
