NullPointerException in DefaultHostnameProvider when authenticating
I have a Docker-infrastructure where I have a backend in a container and keycloak running in another container. When my Backend tries to handle a request the authentication in Keycloak returns with a response code 500.
When I look at the logs in the keycloak-container I see a NullPointerException:
2022-04-28 08:58:57,172 ERROR [org.keycloak.services.error.KeycloakErrorHandler] (executor-thread-6) Uncaught server error: java.lang.NullPointerException
at org.keycloak.quarkus.runtime.hostname.DefaultHostnameProvider.isHostFromFrontEndUrl(DefaultHostnameProvider.java:158)
at org.keycloak.quarkus.runtime.hostname.DefaultHostnameProvider.forNonStrictBackChannel(DefaultHostnameProvider.java:132)
at org.keycloak.quarkus.runtime.hostname.DefaultHostnameProvider.getScheme(DefaultHostnameProvider.java:60)
at org.keycloak.models.KeycloakUriInfo.<init>(KeycloakUriInfo.java:46)
at org.keycloak.services.DefaultKeycloakContext.getUri(DefaultKeycloakContext.java:78)
at org.keycloak.protocol.oidc.OIDCWellKnownProvider.getConfig(OIDCWellKnownProvider.java:111)
at org.keycloak.services.resources.RealmsResource.getWellKnown(RealmsResource.java:267)
at org.jboss.resteasy.core.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:408)
at org.jboss.resteasy.core.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:69)
at io.vertx.ext.web.impl.RoutingContextWrapper.next(RoutingContextWrapper.java:201)
at org.keycloak.quarkus.runtime.integration.web.QuarkusRequestFilter.lambda$createBlockingHandler$1(QuarkusRequestFilter.java:71)
The URL my backend is sending the request to is: http://keycloak:8080/auth/realms/my-realm/.well-known/openid-configuration
When I execute this request in the keycloak-container I get the same error.
When I execute this request with localhost instead of the container-name in the keycloak-container everything works fine.
I don’t know what I’m doing wrong :confused:
I found the problem in my configuration.
My backend was communictating with keycloak through the internal name and keycloak was setup with the public name of the host.
When I set to get everything working with the IP of the host (not tha name of the host as it is not accessible in the containers) everything is working as expected.
