Hi there, Are there any possibilities to display the password strength bar while resetting the password in keycloak?
There is nothing built in to Keycloak that does this. However, you could create a custom login theme that adds one of the many js password strength indicator libs to the username/password page (login.ftl
). Do a google search for “javascript password strength library” and you’ll find a bunch.
