I’m running keycloak-18 with the guide.
I want to know, it’s possible to persist the keycloak’s infinispan cache.
I’m trying to figure this out too. According to this documentation it’s possible: Server Installation and Configuration Guide
However, the documentation talks about the command “standalone.sh”, which doesn’t exist in the current distribution so I’m stuck
I found way to persist infinispan caches by following this documentation instead: Configuring distributed caches - Keycloak.
My setup:
- 2 keycloak instances running on the same network
- Set environment variable
KC_CACHE=ispn
for both instances -
KC_CACHE_STACK=kubernetes
might be necessary when running in kubernetes too
If everything works you should see these log messages:
Infinispan cache persistence enabled:
2022-08-01 12:28:45,567 INFO [org.infinispan.CLUSTER] (keycloak-cache-init) ISPN000078: Starting JGroups channel `ISPN`
Second node joined:
2022-08-01 12:28:58,664 INFO [org.infinispan.CLUSTER] (jgroups-8,4ed11815318d-60515) ISPN100000: Node fe02127deddf-59930 joined the cluster
This way both instances communicate with each other and synchronize sessions. You will be able to restart node 1 while node 2 keeps running and all sessions will stay after node 1 turns back on.
Thanks wb256,
These can let the the keycloak instances sharing infinispan cache with each other.
But if all keycloak instance shutdown, the cache will be lost.
I found something here infinispan_configuring#write-behind_persistence
But seems, keycloak does not opening the cache persistence. I got Unable to persist Infinispan internal caches as no global state enabled
at starting
this discussion can help
Yeah, I am also looking for the same…
I was able to create an external infinispan cluster and connect Keycloak to that using hotrod client.
I used this infinispan configuration file in keycloak (keycloak-project-example/cache-ispn-remote.xml at main · thomasdarimont/keycloak-project-example · GitHub)
Infinispan cluster was created on EC2 instances by using tcp and s3_ping (s3_ping is deprecated now).
Keycloak cluster was on EKS.
references
@nishada, you didn’t consider spinning up infinispan in EKS as you already have Keycloak there too? any specific reason?
~ Copyright 2019 Red Hat, Inc. and/or its affiliates
~ and other contributors as indicated by the @author tags.
~ Licensed under the Apache License, Version 2.0 (the "License");
~ you may not use this file except in compliance with the License.
~ You may obtain a copy of the License at
~ http://www.apache.org/licenses/LICENSE-2.0
~ Unless required by applicable law or agreed to in writing, software
~ distributed under the License is distributed on an "AS IS" BASIS,
~ WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
~ See the License for the specific language governing permissions and
~ limitations under the License.
<infinispan
xsi:schemaLocation="urn:infinispan:config:13.0 http://www.infinispan.org/schemas/infinispan-config-13.0.xsd"
xmlns="urn:infinispan:config:13.0">
<jgroups>
<stack name="jdbc-ping-tcp" extends="tcp">
<JDBC_PING connection_driver="com.mysql.cj.jdbc.Driver"
connection_url="${env.KC_DB_URL}"
connection_username="${env.KC_DB_USERNAME}"
connection_password="${env.KC_DB_PASSWORD}"
initialize_sql="CREATE TABLE IF NOT EXISTS JGROUPSPING (own_addr varchar(200) NOT NULL, cluster_name varchar(200) NOT NULL, ping_data VARBINARY(255), constraint PK_JGROUPSPING PRIMARY KEY (own_addr, cluster_name));"
info_writer_sleep_time="500"
remove_all_data_on_view_change="true"
stack.combine="REPLACE"
stack.position="MPING"/>
</stack>
</jgroups>
<global-state>
<persistent-location path="ispn/"/>
</global-state>
<transport lock-timeout="60000" stack="jdbc-ping-tcp"/>
<local-cache name="realms">
<encoding>
</encoding>
<memory max-count="10000"/>
<!-- <persistence>-->
<!-- <file-store WARNING="DO NOT persist local cache as file-store, it will cause error"/>-->
<!-- </persistence>-->
</local-cache>
<local-cache name="users">
<encoding>
</encoding>
</local-cache>
<expiration lifespan="-1"/>
<persistence>
<file-store preload="true" fetch-state="true"/>
</persistence>
</distributed-cache>
<persistence>
</persistence>
<persistence>
</persistence>
<persistence>
</persistence>
<persistence>
</persistence>
<persistence>
</persistence>
<encoding>
</encoding>
</local-cache>
<persistence>
</persistence>
</replicated-cache>
<local-cache name="keys">
<encoding>
</encoding>
<memory max-count="1000"/>
</local-cache>
<encoding>
</encoding>
<memory max-count="-1"/>
<persistence>
</persistence>
</cache-container>
</infinispan>
this will persist cache as file, due to global-stage
<global-state>
</global-state>
it use jgroups
jdbc-ping-tcp
to communicate with each other
