Hi, hopefully someone has experience of how to setup keycloak with
infinispan as a remote cache.
My goal is to run keycloak across multiple data centres with replicated
database and cache, however i am struggling to get anything working.
I am running keycloak 12.0.4 and infinispan 9.4.20
I have 2 unclustered keycloak instances (A and B), sharing a remote cache
and H2 backend.
When i log in to the admin console on one of the instances (lets say A),
through the shared remote store i’m expecting to see the session on the
other keycloak instance (B). Using the infinispan manager console i can
see that the sessions are being cached as the cache content entries value
increments, from both directions (A + B), however, the values never appear
within the other instance.
Here are snippets of my clustered.xml and standalone-ha.xml
clustered.xml
<replicated-cache-configuration name=“sessions-cfg” mode=“SYNC”
start=“EAGER” batching=“false”>
<transaction mode=“NON_XA” locking=“PESSIMISTIC”/>
</replicated-cache-configuration>
<backups>
<backup site=“site1” failure-policy=“FAIL” strategy=“SYNC” enabled=“true”/>
</backups>
<replicated-cache name=“work” configuration=“sessions-cfg” />
<replicated-cache name=“sessions” configuration=“sessions-cfg” />
<replicated-cache name=“clientSessions” configuration=“sessions-cfg”/>
<replicated-cache name=“offlineSessions” configuration=“sessions-cfg” />
<replicated-cache name=“offlineClientSessions”
<replicated-cache name=“actionTokens” configuration=“sessions-cfg” />
<replicated-cache name=“loginFailures” configuration=“sessions-cfg” />
standalone-ha.xml
<replicated-cache name=“work” mode=“SYNC”>
<remote-store cache=“work” remote-servers=“remote-cache”
passivation=“false” fetch-state=“false” purge=“false” preload=“false”
shared=“true”>
<property name=“rawValues”>true
<property
name=“marshaller”>org.keycloak.cluster.infinispan.KeycloakHotRodMarshallerFactory
</remote-store>
</replicated-cache>
<distributed-cache name=“sessions” mode=“SYNC” owners=“1”>
<remote-store cache=“sessions” remote-servers=“remote-cache”
shared=“true”>
<property
</remote-store>
</distributed-cache>
<distributed-cache name=“offlineSessions” mode=“SYNC” owners=“1”>
<remote-store cache=“offlineSessions” remote-servers=“remote-cache”
shared=“true”>
<property
</remote-store>
<distributed-cache name=“clientSessions” mode=“SYNC” owners=“1”>
<remote-store cache=“clientSessions” remote-servers=“remote-cache”
shared=“true”>
<property
</remote-store>
<distributed-cache name=“offlineClientSessions” mode=“SYNC” owners=“1”>
<remote-store cache=“offlineClientSessions” remote-servers=“remote-cache”
shared=“true”>
<property
</remote-store>
<distributed-cache name=“loginFailures” mode=“SYNC” owners=“1”>
<remote-store cache=“loginFailures” remote-servers=“remote-cache”
shared=“true”>
<property
</remote-store>
<distributed-cache name=“actionTokens” mode=“SYNC” owners=“2”>
<eviction max-entries="-1" strategy=“NONE”/>
<expiration max-idle="-1" interval=“300000”/>
<remote-store cache=“actionTokens” remote-servers=“remote-cache”
passivation=“false” fetch-state=“false” purge=“false” preload=“true”
shared=“true”>
<property
</remote-store>
<distributed-cache name=“authenticationSessions” mode=“SYNC” owners=“1”/>
Backend log from keycloak server
2021-04-19 20:24:46,516 DEBUG [org.keycloak.models.sessions.infinispan.remotestore.RemoteCacheSessionListener] (Thread-0) Received event from remote store. Event ‘CLIENT_CACHE_ENTRY_MODIFIED’, key ‘30abf6ae-cdc6-4691-a6e7-2dff27198178’, skip ‘true’
I guess the “skip” parameter should be false according to official keycloak documentation .
any ideas on what i might be missing?
Thanks
Yogi
