Hi, I am trying to deploy Keycloak in Fargate. I included a self signed cert and key for the keycloak server to use. It works when I deploy this on a barebones EC2 instance, but now when I deploy it on ECS. Here is the error that I run into:
Here is my Dockerfile:
FROM quay.io/keycloak/keycloak:latest as builder
USER root
# ENV KC_HTTP_RELATIVE_PATH=/auth
# ENV KC_CACHE_CONFIG_FILE=cache-ispn-jdbc-ping.xml
# # copy the custom cache config file into the keycloak conf dir
# COPY ./cache-ispn-jdbc-ping.xml /opt/keycloak/conf/cache-ispn-jdbc-ping.xml
WORKDIR /opt/keycloak
# RUN microdnf install -y python3 && microdnf clean all
# RUN curl -O https://bootstrap.pypa.io/pip/3.6/get-pip.py && python3 get-pip.py && pip install boto3
FROM registry.access.redhat.com/ubi9 AS ubi-micro-build
RUN export XH_BINDIR=/usr/local/bin && curl -sfL https://raw.githubusercontent.com/ducaale/xh/master/install.sh | sh
#Python setup script
COPY setup.py /tmp/
COPY realm.json /tmp/
COPY mytruststore.jks /opt/keycloak/conf/truststore.jks
COPY mykeystore.jks /opt/keycloak/conf/keystore.jks
COPY keycloak.conf /opt/keycloak/conf/keycloak.conf
COPY certificate.crt /opt/keycloak/conf/certificate.crt
COPY private.key /opt/keycloak/conf/private.key
# COPY --from=builder /opt/keycloak/ /opt/keycloak/
COPY --from=builder /opt/keycloak/lib/quarkus/ /opt/keycloak/lib/quarkus/
# COPY --from=builder certificate.crt /opt/keycloak/conf/certificate.crt
# COPY --from=builder private.key /opt/keycloak/conf/private.key
ENV KC_METRICS_ENABLED=true
ENV KC_FEATURES=scripts
# ENV KC_DB=postgres
# ENV KC_DB_URL={db_url}
# ENV KC_DB_USERNAME=admin
# ENV KC_DB_PASSWORD=admin
ENV KEYCLOAK_ADMIN=admin
ENV KEYCLOAK_ADMIN_PASSWORD=password
ENV KC_HTTPS_CERTIFICATE_FILE=/opt/keycloak/conf/certificate.crt
ENV KC_HTTPS_CERTIFICATE_KEY_FILE=/opt/keycloak/conf/private.key
#Entrypoint script
RUN /opt/keycloak/bin/kc.sh show-config
ENTRYPOINT ["/opt/keycloak/bin/kc.sh", "start-dev"]
what am I doing wrong?? Please help
