Hi all,
I’m trying to use Keycloak 19.0.1 as an OIDC broker to an external IdP. This IdP requires basic authentication for the Token request, which I have chosen in the drop down menu (img below). The authorization step passes. But during my tests there is no Authorization: Basic header sent with the token request and the request fails. I’ve captured the request and the Client secret is included in the POST form.
Am I missing something? Could it be a bug?
According to the specification at Final: OpenID Connect Core 1.0 incorporating errata set 1 , Basic is a supported and default authentication method.
The failed request log:
2022-09-16 10:08:38,327 ERROR [org.keycloak.broker.oidc.AbstractOAuth2IdentityProvider] (executor-thread-28) Failed to make identity provider oauth callback: org.keycloak.broker.provider.IdentityBrokerException: No access_token from server. error='invalid_client', error_description='Client authentication is required', error_uri='null'
at org.keycloak.broker.oidc.OIDCIdentityProvider.verifyAccessToken(OIDCIdentityProvider.java:526)
at org.keycloak.broker.oidc.OIDCIdentityProvider.getFederatedIdentity(OIDCIdentityProvider.java:369)
at org.keycloak.broker.oidc.AbstractOAuth2IdentityProvider$Endpoint.authResponse(AbstractOAuth2IdentityProvider.java:502)
at org.keycloak.quarkus.runtime.integration.web.QuarkusRequestFilter.lambda$createBlockingHandler$1(QuarkusRequestFilter.java:90)
at io.quarkus.vertx.core.runtime.VertxCoreRecorder$13.runWith(VertxCoreRecorder.java:545)
at java.base/java.lang.Thread.run(Thread.java:829
IdP settings
