Hi!
We are new to keycloak and just about to start configuring it for a HA production environment.
We will run it in kubernetes and start with keycloak 17.
While everything seem to work, response times are extremely slow at startup, upgrades and if a pod dies. After that it takes a couple of minutes and response times are reasonable again. Is something missing in the configuration?
The Dockerfile to build keycloak 17:
FROM quay.io/keycloak/keycloak:17.0.0 as builder
ENV KC_METRICS_ENABLED=true \
KC_DB=mysql \
KC_CACHE_STACK=kubernetes \
KC_STACK=ispn
COPY --from=builder /opt/keycloak/lib/quarkus/ /opt/keycloak/lib/quarkus/
ENTRYPOINT ["/opt/keycloak/bin/kc.sh"]
Statefulset + Service:
apiVersion: apps/v1
kind: StatefulSet
metadata:
labels:
app: keycloak
spec:
serviceName: keycloak-headless
replicas: 2
selector:
matchLabels:
app: keycloak
template:
metadata:
labels:
app: keycloak
spec:
containers:
- name: keycloak
image: # image-built-from-dockerfile
args: ["-Djgroups.dns.query=keycloak-headless", "start"]
env:
- name: KEYCLOAK_ADMIN
value: "admin"
- name: KEYCLOAK_ADMIN_PASSWORD
value: # admin password
- name: KC_HOSTNAME
value: # host
- name: KC_HOSTNAME_STRICT_BACKCHANNEL
value: "true"
- name: KC_PROXY
value: "edge"
- name: KC_DB_USERNAME
value: # db username
- name: KC_DB_PASSWORD
value: # db password
- name: KC_DB_URL_HOST
value: # db host
- name: KC_DB_URL_PROPERTIES
value: "?characterEncoding=UTF-8"
ports:
- name: http
containerPort: 8080
resources:
requests:
memory: "2Gi"
cpu: "500m"
limits:
memory: "4Gi"
cpu: "1000m"
readinessProbe:
httpGet:
path: /realms/master
port: 8080
apiVersion: v1
kind: Service
metadata:
labels:
app: keycloak
spec:
type: ClusterIP
clusterIP: None
ports:
- name: http
port: 8080
targetPort: 8080
selector:
app: keycloak
And the ingress:
kind: Ingress
metadata:
annotations:
nginx.ingress.kubernetes.io/affinity: "cookie"
nginx.ingress.kubernetes.io/session-cookie-name: "KC_SC"
nginx.ingress.kubernetes.io/affinity-mode: "balanced"
spec:
rules:
- host: # host
http:
paths:
- path: /
pathType: Prefix
backend:
service:
port:
number: 8080
