Hi there.
I am struggling with X.509 client certificate authentication. I set “CRL Checking Enabled” at “X509/Validate Username Form” on Keycloak 9.0.2. Then I tried to log-in, browser moved to the authentication error page and outputted the following error in the logs.
ERROR [org.keycloak.services] (default task-77) Not possible to verify signature on CRL. X509 certificate doesn't have CA chain available on it: java.security.GeneralSecurityException: Not possible to verify signature on CRL. X509 certificate doesn't have CA chain available on it
at org.keycloak.keycloak-services@9.0.2//org.keycloak.utils.CRLUtils.check(CRLUtils.java:116)
at org.keycloak.keycloak-services@9.0.2//org.keycloak.authentication.authenticators.x509.CertificateValidator.checkRevocationStatusUsingCRL(CertificateValidator.java:563)
at org.keycloak.keycloak-services@9.0.2//org.keycloak.authentication.authenticators.x509.CertificateValidator.checkRevocationStatusUsingCRLDistributionPoints(CertificateValidator.java:585)
at org.keycloak.keycloak-services@9.0.2//org.keycloak.authentication.authenticators.x509.CertificateValidator.checkRevocationStatus(CertificateValidator.java:597)
at org.keycloak.keycloak-services@9.0.2//org.keycloak.authentication.authenticators.x509.X509ClientCertificateAuthenticator.authenticate(X509ClientCertificateAuthenticator.java:85)
at org.keycloak.keycloak-services@9.0.2//org.keycloak.authentication.DefaultAuthenticationFlow.processSingleFlowExecutionModel(DefaultAuthenticationFlow.java:438)
at org.keycloak.keycloak-services@9.0.2//org.keycloak.authentication.DefaultAuthenticationFlow.processFlow(DefaultAuthenticationFlow.java:247)
at org.keycloak.keycloak-services@9.0.2//org.keycloak.authentication.DefaultAuthenticationFlow.processSingleFlowExecutionModel(DefaultAuthenticationFlow.java:381)
at org.keycloak.keycloak-services@9.0.2//org.keycloak.authentication.DefaultAuthenticationFlow.continueAuthenticationAfterSuccessfulAction(DefaultAuthenticationFlow.java:180)
at org.keycloak.keycloak-services@9.0.2//org.keycloak.authentication.DefaultAuthenticationFlow.processAction(DefaultAuthenticationFlow.java:158)
at org.keycloak.keycloak-services@9.0.2//org.keycloak.authentication.AuthenticationProcessor.authenticationAction(AuthenticationProcessor.java:936)
at org.keycloak.keycloak-services@9.0.2//org.keycloak.services.resources.LoginActionsService.processFlow(LoginActionsService.java:311)
at org.keycloak.keycloak-services@9.0.2//org.keycloak.services.resources.LoginActionsService.processAuthentication(LoginActionsService.java:282)
at org.keycloak.keycloak-services@9.0.2//org.keycloak.services.resources.LoginActionsService.authenticate(LoginActionsService.java:266)
at org.keycloak.keycloak-services@9.0.2//org.keycloak.services.resources.LoginActionsService.authenticateForm(LoginActionsService.java:339)
at org.jboss.resteasy.resteasy-jaxrs@3.9.1.Final//org.jboss.resteasy.core.MethodInjectorImpl.invoke(MethodInjectorImpl.java:138)
at org.jboss.resteasy.resteasy-jaxrs@3.9.1.Final//org.jboss.resteasy.core.ResourceMethodInvoker.internalInvokeOnTarget(ResourceMethodInvoker.java:517)
at org.jboss.resteasy.resteasy-jaxrs@3.9.1.Final//org.jboss.resteasy.core.ResourceMethodInvoker.invokeOnTargetAfterFilter(ResourceMethodInvoker.java:406)
at org.jboss.resteasy.resteasy-jaxrs@3.9.1.Final//org.jboss.resteasy.core.ResourceMethodInvoker.lambda$invokeOnTarget$0(ResourceMethodInvoker.java:370)
at org.jboss.resteasy.resteasy-jaxrs@3.9.1.Final//org.jboss.resteasy.core.interception.PreMatchContainerRequestContext.filter(PreMatchContainerRequestContext.java:356)
at org.jboss.resteasy.resteasy-jaxrs@3.9.1.Final//org.jboss.resteasy.core.ResourceMethodInvoker.invokeOnTarget(ResourceMethodInvoker.java:372)
at org.jboss.resteasy.resteasy-jaxrs@3.9.1.Final//org.jboss.resteasy.core.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:344)
at org.jboss.resteasy.resteasy-jaxrs@3.9.1.Final//org.jboss.resteasy.core.ResourceLocatorInvoker.invokeOnTargetObject(ResourceLocatorInvoker.java:137)
at org.jboss.resteasy.resteasy-jaxrs@3.9.1.Final//org.jboss.resteasy.core.ResourceLocatorInvoker.invoke(ResourceLocatorInvoker.java:100)
at org.jboss.resteasy.resteasy-jaxrs@3.9.1.Final//org.jboss.resteasy.core.SynchronousDispatcher.invoke(SynchronousDispatcher.java:440)
at org.jboss.resteasy.resteasy-jaxrs@3.9.1.Final//org.jboss.resteasy.core.SynchronousDispatcher.lambda$invoke$4(SynchronousDispatcher.java:229)
at org.jboss.resteasy.resteasy-jaxrs@3.9.1.Final//org.jboss.resteasy.core.SynchronousDispatcher.lambda$preprocess$0(SynchronousDispatcher.java:135)
at org.jboss.resteasy.resteasy-jaxrs@3.9.1.Final//org.jboss.resteasy.core.SynchronousDispatcher.preprocess(SynchronousDispatcher.java:138)
at org.jboss.resteasy.resteasy-jaxrs@3.9.1.Final//org.jboss.resteasy.core.SynchronousDispatcher.invoke(SynchronousDispatcher.java:215)
at org.jboss.resteasy.resteasy-jaxrs@3.9.1.Final//org.jboss.resteasy.plugins.server.servlet.ServletContainerDispatcher.service(ServletContainerDispatcher.java:227)
at org.jboss.resteasy.resteasy-jaxrs@3.9.1.Final//org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.service(HttpServletDispatcher.java:56)
at org.jboss.resteasy.resteasy-jaxrs@3.9.1.Final//org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.service(HttpServletDispatcher.java:51)
at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.ServletHandler.handleRequest(ServletHandler.java:74)
at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.FilterHandler$FilterChainImpl.doFilter(FilterHandler.java:129)
at org.keycloak.keycloak-services@9.0.2//org.keycloak.services.filters.KeycloakSessionServletFilter.doFilter(KeycloakSessionServletFilter.java:91)
at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.core.ManagedFilter.doFilter(ManagedFilter.java:61)
at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.FilterHandler$FilterChainImpl.doFilter(FilterHandler.java:131)
at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.FilterHandler.handleRequest(FilterHandler.java:84)
at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.security.ServletSecurityRoleHandler.handleRequest(ServletSecurityRoleHandler.java:62)
at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.ServletChain$1.handleRequest(ServletChain.java:68)
at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.ServletDispatchingHandler.handleRequest(ServletDispatchingHandler.java:36)
at org.wildfly.extension.undertow@18.0.1.Final//org.wildfly.extension.undertow.security.SecurityContextAssociationHandler.handleRequest(SecurityContextAssociationHandler.java:78)
at io.undertow.core@2.0.27.Final//io.undertow.server.handlers.PredicateHandler.handleRequest(PredicateHandler.java:43)
at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.RedirectDirHandler.handleRequest(RedirectDirHandler.java:68)
at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.security.SSLInformationAssociationHandler.handleRequest(SSLInformationAssociationHandler.java:132)
at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.security.ServletAuthenticationCallHandler.handleRequest(ServletAuthenticationCallHandler.java:57)
at io.undertow.core@2.0.27.Final//io.undertow.security.handlers.AbstractConfidentialityHandler.handleRequest(AbstractConfidentialityHandler.java:46)
at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.security.ServletConfidentialityConstraintHandler.handleRequest(ServletConfidentialityConstraintHandler.java:64)
at io.undertow.core@2.0.27.Final//io.undertow.security.handlers.AuthenticationMechanismsHandler.handleRequest(AuthenticationMechanismsHandler.java:60)
at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.security.CachedAuthenticatedSessionHandler.handleRequest(CachedAuthenticatedSessionHandler.java:77)
at io.undertow.core@2.0.27.Final//io.undertow.security.handlers.NotificationReceiverHandler.handleRequest(NotificationReceiverHandler.java:50)
at io.undertow.core@2.0.27.Final//io.undertow.security.handlers.AbstractSecurityContextAssociationHandler.handleRequest(AbstractSecurityContextAssociationHandler.java:43)
at org.wildfly.extension.undertow@18.0.1.Final//org.wildfly.extension.undertow.security.jacc.JACCContextIdHandler.handleRequest(JACCContextIdHandler.java:61)
at org.wildfly.extension.undertow@18.0.1.Final//org.wildfly.extension.undertow.deployment.GlobalRequestControllerHandler.handleRequest(GlobalRequestControllerHandler.java:68)
at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.ServletInitialHandler.handleFirstRequest(ServletInitialHandler.java:269)
at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.ServletInitialHandler.access$100(ServletInitialHandler.java:78)
at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:133)
at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:130)
at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.core.ServletRequestContextThreadSetupAction$1.call(ServletRequestContextThreadSetupAction.java:48)
at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.core.ContextClassLoaderSetupAction$1.call(ContextClassLoaderSetupAction.java:43)
at org.wildfly.extension.undertow@18.0.1.Final//org.wildfly.extension.undertow.security.SecurityContextThreadSetupAction.lambda$create$0(SecurityContextThreadSetupAction.java:105)
at org.wildfly.extension.undertow@18.0.1.Final//org.wildfly.extension.undertow.deployment.UndertowDeploymentInfoService$UndertowThreadSetupAction.lambda$create$0(UndertowDeploymentInfoService.java:1504)
at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.ServletInitialHandler.dispatchRequest(ServletInitialHandler.java:249)
at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.ServletInitialHandler.access$000(ServletInitialHandler.java:78)
at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.ServletInitialHandler$1.handleRequest(ServletInitialHandler.java:99)
at io.undertow.core@2.0.27.Final//io.undertow.server.Connectors.executeRootHandler(Connectors.java:376)
at io.undertow.core@2.0.27.Final//io.undertow.server.HttpServerExchange$1.run(HttpServerExchange.java:830)
I looked up codes of CRLUtils.check
, and I found that the error to be thrown when a submitted client certificate chain is less than 2. I’m using a client certificate that is directly trusted by a CA.
It seems like major browsers like Chrome and Firefox omit sending the CA certificate. Therefore, it looks like the submitted certificate chain becomes less than 2, and causes the error.
Is there any workaround to the problem and use CRL checks?
Any help or suggestion is highly appreciated.
Thank you.
