I’m currently trying to configure the cache JDBC store for Infinispan.
I’m running Keycloak in ECS and don’t want to lose all user sessions, etc. every time I’m deploying a new version of the Keycloak service.
Since Redis is not working in WildFly, I tried the JDBC store. With a bit of tinkering I got it set up and Keycloak even creates the database tables on start.
Whenever Keycloak pushes an entry into the cache, it throws an exception.
14:29:28,237 ERROR [org.infinispan.interceptors.impl.InvocationContextInterceptor] (default task-6) ISPN000136: Error executing command PutKeyValueCommand on Cache 'clientSessions', writing keys [7ae59e20-57b7-4a4f-85bc-dc609a96cb9c]: org.infinispan.persistence.keymappers.UnsupportedKeyTypeException: Unsupported key type: 'java.util.UUID' on key: 7ae59e20-57b7-4a4f-85bc-dc609a96cb9c
I’m using Keycloak 12.0.1 with MySQL 5.7 and the JDBC store is enabled by a script that contains these two lines for every distributed-cache entry:
/subsystem=infinispan/cache-container=keycloak/distributed-cache=clientSessions/store=jdbc:add(data-source=KeycloakDS)
/subsystem=infinispan/cache-container=keycloak/distributed-cache=clientSessions/store=jdbc/table=string:write-attribute(name=id-column, value={type="VARCHAR(200)"})
This happens with store=jdbc
as well as store=binary-jdbc
Am I missing something that I need to configure? Is this missing some marshaller? Do I need to create additional data-column
s?
Also the default create statements for the JDBC store are not working with MySQL, is there some undocumented configuration to tell Infinispan what DB vendor it is talking to?
