/admin/realms/admin/users does not return [UserRepresentation]
When doing a GET to /admin/realms/admin/users, I get a slim version of UserRepresentation:
   "id":"2b8f5030-d197-47f9-9b3b-631b2408fd7a",
   "createdTimestamp":1623094859490,
   "username":"admin",
   "enabled":true,
   "totp":false,
   "emailVerified":false,
   "firstName":"Admin",
   "disableableCredentialTypes":[],
   "requiredActions":[],
   "notBefore":0,
   "access":{
      "manageGroupMembership":true,
      "view":true,
      "mapRoles":true,
      "impersonate":true,
      "manage":true
I need for instance groups to also be returned.
Any idea why this is happening?
Anyone with any ideas?
This is the representation returned by the GET /{realm}/users endpoint of the current Admin API. In order to get the user’s groups, you have to call the GET /{realm}/users/{id}/groups endpoint: Keycloak Admin REST API
Hi all,
What is the corresponding class for the endpoints HTTPGET "admin/realms/{{realm}}/users/{{userId}} and HTTPGET “admin/realms/{{realm}}/ui-ext/brute-force-user?briefRepresentation=false&first=0&max=11&search=*”, HTTPPUT "admin/realms/{{realm}}/users/{{userId}} ?
Is this one https://github.com/keycloak/keycloak/blob/main/core/src/main/java/org/keycloak/representations/idm/UserRepresentation.java?
Thank you in advance!
Yes. Those idm classes are the ones used by the API methods.
As much i have found about this in the latest docs and code of keycloak.We may use something called the BreifRepresentation key to actually get the all the details. here is the image
It is passed as the query parameter as well. here is the link of the docs as well.
Hope it helps.
