Hi, guys, Keycloak works well while I am using H2 database. But I want to switch to using Firebird as database.
So, I have the following path D:\Keycloak\modules\system\layers\keycloak\org\firebirdsql\main, where is jaybird-3.0.9.jar and its module.xml
<module xmlns="urn:jboss:module:1.3" name="org.firebirdsql">
<resources>
<resource-root path="jaybird-3.0.9.jar"/>
</resources>
<dependencies>
<module name="javax.api"/>
<module name="javax.transaction.api"/>
<module name="javax.resource.api"/>
</dependencies>
</module>
So, I’ve changed standalone.xml:
<datasources>
<datasource jndi-name="java:jboss/datasources/ExampleDS" pool-name="ExampleDS" enabled="true" use-java-context="true" statistics-enabled="${wildfly.datasources.statistics-enabled:${wildfly.statistics-enabled:false}}">
<connection-url>jdbc:h2:mem:test;DB_CLOSE_DELAY=-1;DB_CLOSE_ON_EXIT=FALSE</connection-url>
<driver>h2</driver>
<security>
<user-name>sa</user-name>
<password>sa</password>
</security>
</datasource>
<datasource jndi-name="java:jboss/datasources/KeycloakDS" pool-name="KeycloakDS" enabled="true" use-java-context="true" statistics-enabled="${wildfly.datasources.statistics-enabled:${wildfly.statistics-enabled:false}}">
<connection-url>jdbc:firebirdsql://localhost:3050/D:\KeycloakDB\KeycloakDB.FDB</connection-url>
<driver>firebirdsql</driver>
<security>
<user-name>SYSDBA</user-name>
<password>masterkey</password>
</security>
</datasource>
<drivers>
<driver name="h2" module="com.h2database.h2">
<xa-datasource-class>org.h2.jdbcx.JdbcDataSource</xa-datasource-class>
</driver>
<driver name="firebirdsql" module="org.firebirdsql">
<driver-class>org.firebirdsql.jdbc.FBDriver</driver-class>
</driver>
</drivers>
</datasources>
But this doesn’t work for me. While starting Keycloak, I get many consecutive error messages, starting with this one:
11:54:20,709 FATAL [org.keycloak.services] (ServerService Thread Pool -- 68) Error during startup: java.lang.RuntimeException: Exception invoking method [listUnrunChangeSets] on object [liquibase.Liquibase@5163cec2], using arguments [null,(),false]
at org.keycloak.keycloak-common@11.0.2//org.keycloak.common.util.reflections.Reflections.invokeMethod(Reflections.java:385)
at org.keycloak.keycloak-model-jpa@11.0.2//org.keycloak.connections.jpa.updater.liquibase.LiquibaseJpaUpdaterProvider.getLiquibaseUnrunChangeSets(LiquibaseJpaUpdaterProvider.java:285)
at org.keycloak.keycloak-model-jpa@11.0.2//org.keycloak.connections.jpa.updater.liquibase.LiquibaseJpaUpdaterProvider.validateChangeSet(LiquibaseJpaUpdaterProvider.java:253)
at org.keycloak.keycloak-model-jpa@11.0.2//org.keycloak.connections.jpa.updater.liquibase.LiquibaseJpaUpdaterProvider.validate(LiquibaseJpaUpdaterProvider.java:226)
at org.keycloak.keycloak-model-jpa@11.0.2//org.keycloak.connections.jpa.DefaultJpaConnectionProviderFactory.migration(DefaultJpaConnectionProviderFactory.java:301)
at org.keycloak.keycloak-model-jpa@11.0.2//org.keycloak.connections.jpa.DefaultJpaConnectionProviderFactory.lambda$lazyInit$0(DefaultJpaConnectionProviderFactory.java:182)
at org.keycloak.keycloak-server-spi-private@11.0.2//org.keycloak.models.utils.KeycloakModelUtils.suspendJtaTransaction(KeycloakModelUtils.java:682)
at org.keycloak.keycloak-model-jpa@11.0.2//org.keycloak.connections.jpa.DefaultJpaConnectionProviderFactory.lazyInit(DefaultJpaConnectionProviderFactory.java:133)
at org.keycloak.keycloak-model-jpa@11.0.2//org.keycloak.connections.jpa.DefaultJpaConnectionProviderFactory.create(DefaultJpaConnectionProviderFactory.java:81)
at org.keycloak.keycloak-model-jpa@11.0.2//org.keycloak.connections.jpa.DefaultJpaConnectionProviderFactory.create(DefaultJpaConnectionProviderFactory.java:59)
at org.keycloak.keycloak-services@11.0.2//org.keycloak.services.DefaultKeycloakSession.getProvider(DefaultKeycloakSession.java:218)
at org.keycloak.keycloak-model-jpa@11.0.2//org.keycloak.models.jpa.JpaRealmProviderFactory.create(JpaRealmProviderFactory.java:51)
at org.keycloak.keycloak-model-jpa@11.0.2//org.keycloak.models.jpa.JpaRealmProviderFactory.create(JpaRealmProviderFactory.java:33)
at org.keycloak.keycloak-services@11.0.2//org.keycloak.services.DefaultKeycloakSession.realmLocalStorage(DefaultKeycloakSession.java:171)
at org.keycloak.keycloak-model-infinispan@11.0.2//org.keycloak.models.cache.infinispan.RealmCacheSession.getRealmDelegate(RealmCacheSession.java:148)
at org.keycloak.keycloak-model-infinispan@11.0.2//org.keycloak.models.cache.infinispan.RealmCacheSession.getMigrationModel(RealmCacheSession.java:141)
at org.keycloak.keycloak-server-spi-private@11.0.2//org.keycloak.migration.MigrationModelManager.migrate(MigrationModelManager.java:97)
at org.keycloak.keycloak-services@11.0.2//org.keycloak.services.resources.KeycloakApplication.migrateModel(KeycloakApplication.java:234)
at org.keycloak.keycloak-services@11.0.2//org.keycloak.services.resources.KeycloakApplication.migrateAndBootstrap(KeycloakApplication.java:175)
at org.keycloak.keycloak-services@11.0.2//org.keycloak.services.resources.KeycloakApplication$1.run(KeycloakApplication.java:137)
at org.keycloak.keycloak-server-spi-private@11.0.2//org.keycloak.models.utils.KeycloakModelUtils.runJobInTransaction(KeycloakModelUtils.java:227)
at org.keycloak.keycloak-services@11.0.2//org.keycloak.services.resources.KeycloakApplication.startup(KeycloakApplication.java:128)
at org.keycloak.keycloak-wildfly-extensions@11.0.2//org.keycloak.provider.wildfly.WildflyPlatform.onStartup(WildflyPlatform.java:29)
at org.keycloak.keycloak-services@11.0.2//org.keycloak.services.resources.KeycloakApplication.<init>(KeycloakApplication.java:114)
at java.base/java.lang.reflect.Constructor.newInstanceWithCaller(Constructor.java:500)
at java.base/java.lang.reflect.Constructor.newInstance(Constructor.java:481)
at org.jboss.resteasy.resteasy-jaxrs@3.12.1.Final//org.jboss.resteasy.core.ConstructorInjectorImpl.construct(ConstructorInjectorImpl.java:152)
at org.jboss.resteasy.resteasy-jaxrs@3.12.1.Final//org.jboss.resteasy.spi.ResteasyProviderFactory.createProviderInstance(ResteasyProviderFactory.java:2811)
at org.jboss.resteasy.resteasy-jaxrs@3.12.1.Final//org.jboss.resteasy.spi.ResteasyDeployment.createApplication(ResteasyDeployment.java:371)
at org.jboss.resteasy.resteasy-jaxrs@3.12.1.Final//org.jboss.resteasy.spi.ResteasyDeployment.startInternal(ResteasyDeployment.java:283)
at org.jboss.resteasy.resteasy-jaxrs@3.12.1.Final//org.jboss.resteasy.spi.ResteasyDeployment.start(ResteasyDeployment.java:93)
at org.jboss.resteasy.resteasy-jaxrs@3.12.1.Final//org.jboss.resteasy.plugins.server.servlet.ServletContainerDispatcher.init(ServletContainerDispatcher.java:140)
at org.jboss.resteasy.resteasy-jaxrs@3.12.1.Final//org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.init(HttpServletDispatcher.java:42)
at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.core.LifecyleInterceptorInvocation.proceed(LifecyleInterceptorInvocation.java:117)
at org.wildfly.extension.undertow@20.0.1.Final//org.wildfly.extension.undertow.security.RunAsLifecycleInterceptor.init(RunAsLifecycleInterceptor.java:78)
at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.core.LifecyleInterceptorInvocation.proceed(LifecyleInterceptorInvocation.java:103)
at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.core.ManagedServlet$DefaultInstanceStrategy.start(ManagedServlet.java:305)
at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.core.ManagedServlet.createServlet(ManagedServlet.java:145)
at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.core.DeploymentManagerImpl$2.call(DeploymentManagerImpl.java:585)
at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.core.DeploymentManagerImpl$2.call(DeploymentManagerImpl.java:556)
at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.core.ServletRequestContextThreadSetupAction$1.call(ServletRequestContextThreadSetupAction.java:42)
at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.core.ContextClassLoaderSetupAction$1.call(ContextClassLoaderSetupAction.java:43)
at org.wildfly.extension.undertow@20.0.1.Final//org.wildfly.extension.undertow.security.SecurityContextThreadSetupAction.lambda$create$0(SecurityContextThreadSetupAction.java:105)
at org.wildfly.extension.undertow@20.0.1.Final//org.wildfly.extension.undertow.deployment.UndertowDeploymentInfoService$UndertowThreadSetupAction.lambda$create$0(UndertowDeploymentInfoService.java:1530)
at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.core.DeploymentManagerImpl.start(DeploymentManagerImpl.java:598)
at org.wildfly.extension.undertow@20.0.1.Final//org.wildfly.extension.undertow.deployment.UndertowDeploymentService.startContext(UndertowDeploymentService.java:97)
at org.wildfly.extension.undertow@20.0.1.Final//org.wildfly.extension.undertow.deployment.UndertowDeploymentService$1.run(UndertowDeploymentService.java:78)
at java.base/java.lang.Thread.run(Thread.java:832)
at org.jboss.threads@2.3.3.Final//org.jboss.threads.JBossThread.run(JBossThread.java:485)
The question is what am I doing wrong? Please help me with this. Thank you.
