Hi so Im facing this problem which I’m not able to connect to oracle database from inside the container, Im using keycloak image but don’t think that does matter because when I run it locally it works fine but it can’t detect the port on the localhost from inside the container this is the error
2024-03-05 12:00:37,814 INFO [org.keycloak.quarkus.runtime.hostname.DefaultHostnameProvider] (main) Hostname settings: Base URL: <unset>, Hostname: localhost, Strict HTTPS: false, Path: <request>, Strict BackChannel: false, Admin URL: <unset>, Admin: <request>, Port: -1, Proxied: false
2024-03-05 12:00:39,966 WARN [io.agroal.pool] (agroal-11) Datasource '<default>': ORA-12541: Cannot connect. No listener at host localhost port 1521. (CONNECTION_ID=o4V7gJfoQkyngTkFPGwGew==)
https://docs.oracle.com/error-help/db/ora-12541/
2024-03-05 12:00:39,968 WARN [org.hibernate.engine.jdbc.env.internal.JdbcEnvironmentInitiator] (JPA Startup Thread) HHH000342: Could not obtain connection to query metadata: java.lang.NullPointerException: Cannot invoke "org.hibernate.engine.jdbc.spi.SqlExceptionHelper.convert(java.sql.SQLException, String)" because the return value of "org.hibernate.resource.transaction.backend.jta.internal.JtaIsolationDelegate.sqlExceptionHelper()" is null
at org.hibernate.resource.transaction.backend.jta.internal.JtaIsolationDelegate.doTheWork(JtaIsolationDelegate.java:186)
at org.hibernate.resource.transaction.backend.jta.internal.JtaIsolationDelegate.lambda$delegateWork$1(JtaIsolationDelegate.java:75)
at org.hibernate.resource.transaction.backend.jta.internal.JtaIsolationDelegate.doInSuspendedTransaction(JtaIsolationDelegate.java:107)
at org.hibernate.resource.transaction.backend.jta.internal.JtaIsolationDelegate.delegateWork(JtaIsolationDelegate.java:72)
at org.hibernate.engine.jdbc.env.internal.JdbcEnvironmentInitiator.getJdbcEnvironmentUsingJdbcMetadata(JdbcEnvironmentInitiator.java:279)
at org.hibernate.engine.jdbc.env.internal.JdbcEnvironmentInitiator.initiateService(JdbcEnvironmentInitiator.java:193)
at org.hibernate.engine.jdbc.env.internal.JdbcEnvironmentInitiator.initiateService(JdbcEnvironmentInitiator.java:69)
at org.hibernate.boot.registry.internal.StandardServiceRegistryImpl.initiateService(StandardServiceRegistryImpl.java:119)
at org.hibernate.service.internal.AbstractServiceRegistryImpl.createService(AbstractServiceRegistryImpl.java:264)
at org.hibernate.service.internal.AbstractServiceRegistryImpl.initializeService(AbstractServiceRegistryImpl.java:239)
at org.hibernate.service.internal.AbstractServiceRegistryImpl.getService(AbstractServiceRegistryImpl.java:216)
at org.hibernate.engine.jdbc.internal.JdbcServicesImpl.configure(JdbcServicesImpl.java:52)
at org.hibernate.boot.registry.internal.StandardServiceRegistryImpl.configureService(StandardServiceRegistryImpl.java:125)
at org.hibernate.service.internal.AbstractServiceRegistryImpl.initializeService(AbstractServiceRegistryImpl.java:248)
at org.hibernate.boot.internal.SessionFactoryOptionsBuilder.<init>(SessionFactoryOptionsBuilder.java:273)
at io.quarkus.hibernate.orm.runtime.recording.PrevalidatedQuarkusMetadata.buildSessionFactoryOptionsBuilder(PrevalidatedQuarkusMetadata.java:70)
at io.quarkus.hibernate.orm.runtime.boot.FastBootEntityManagerFactoryBuilder.build(FastBootEntityManagerFactoryBuilder.java:81)
at io.quarkus.hibernate.orm.runtime.FastBootHibernatePersistenceProvider.createEntityManagerFactory(FastBootHibernatePersistenceProvider.java:74)
at jakarta.persistence.Persistence.createEntityManagerFactory(Persistence.java:80)
at jakarta.persistence.Persistence.createEntityManagerFactory(Persistence.java:55)
at io.quarkus.hibernate.orm.runtime.JPAConfig$LazyPersistenceUnit.get(JPAConfig.java:156)
at io.quarkus.hibernate.orm.runtime.JPAConfig$1.run(JPAConfig.java:64)
at java.base/java.lang.Thread.run(Thread.java:840)
2024-03-05 12:00:40,318 WARN [org.infinispan.PERSISTENCE] (keycloak-cache-init) ISPN000554: jboss-marshalling is deprecated and planned for removal
2024-03-05 12:00:40,367 WARN [org.infinispan.CONFIG] (keycloak-cache-init) ISPN000569: Unable to persist Infinispan internal caches as no global state enabled
2024-03-05 12:00:40,473 INFO [org.infinispan.CONTAINER] (keycloak-cache-init) ISPN000556: Starting user marshaller 'org.infinispan.jboss.marshalling.core.JBossUserMarshaller'
2024-03-05 12:00:41,103 INFO [org.keycloak.broker.provider.AbstractIdentityProviderMapper] (main) Registering class org.keycloak.broker.provider.mappersync.ConfigSyncEventListener
2024-03-05 12:00:41,153 INFO [org.keycloak.connections.infinispan.DefaultInfinispanConnectionProviderFactory] (main) Node name: node_444305, Site name: null
2024-03-05 12:00:41,172 WARN [io.agroal.pool] (agroal-11) Datasource '<default>': ORA-12541: Cannot connect. No listener at host localhost port 1521. (CONNECTION_ID=0uoi2gStTgG7XUByvXYseQ==)
2024-03-05 12:00:41,238 ERROR [org.keycloak.quarkus.runtime.cli.ExecutionExceptionHandler] (main) ERROR: Failed to start server in (development) mode
2024-03-05 12:00:41,239 ERROR [org.keycloak.quarkus.runtime.cli.ExecutionExceptionHandler] (main) ERROR: Failed to obtain JDBC connection
2024-03-05 12:00:41,239 ERROR [org.keycloak.quarkus.runtime.cli.ExecutionExceptionHandler] (main) ERROR: ORA-12541: Cannot connect. No listener at host localhost port 1521. (CONNECTION_ID=0uoi2gStTgG7XUByvXYseQ==)
2024-03-05 12:00:41,240 ERROR [org.keycloak.quarkus.runtime.cli.ExecutionExceptionHandler] (main) For more details run the same command passing the '--verbose' option. Also you can use '--help' to see the details about the usage of the particular command.
here is my dockerfile
FROM quay.io/keycloak/keycloak:23.0.6
ENV KC_DB=oracle
ENV KC_DB_URL_HOST=localhost
ENV KC_DB_URL_DATABASE=xe
ENV KC_DB_URL_PORT=1521
ENV KC_HOSTNAME=localhost
ENV KC_DB_USERNAME=keycloak
ENV KC_DB_PASSWORD=keycloak
ENV KC_TRANSACTION_XA_ENABLED=false
#Enable HTTP
ENV KC_HTTP_ENABLED=true
# Enable health support
ENV KC_HEALTH_ENABLED=true
# Enable metrics support
ENV KC_METRICS_ENABLED=true
ENTRYPOINT ["/opt/keycloak/bin/kc.sh"]
I even changed my listener.ora to this
# listener.ora Network Configuration File: C:\oracle_xe\product\18.0.0\dbhomeXE\NETWORK\ADMIN\listener.ora
# Generated by Oracle configuration tools.
DEFAULT_SERVICE_LISTENER = XE
SID_LIST_LISTENER =
(SID_LIST =
(SID_DESC =
(SID_NAME = CLRExtProc)
(ORACLE_HOME = C:\oracle_xe\product\18.0.0\dbhomeXE)
(PROGRAM = extproc)
(ENVS = "EXTPROC_DLLS=ONLY:C:\oracle_xe\product\18.0.0\dbhomeXE\bin\oraclr18.dll")
LISTENER =
(DESCRIPTION_LIST =
(DESCRIPTION =
(ADDRESS = (PROTOCOL = TCP)(HOST = 0.0.0.0)(PORT = 1521))
(ADDRESS = (PROTOCOL = IPC)(KEY = EXTPROC1521))
and tsnames.ora to this
# tnsnames.ora Network Configuration File: C:\oracle_xe\product\18.0.0\dbhomeXE\NETWORK\ADMIN\tnsnames.ora
XE =
(DESCRIPTION =
(CONNECT_DATA =
(SERVER = DEDICATED)
(SERVICE_NAME = XE)
LISTENER_XE =
ORACLR_CONNECTION_DATA =
(DESCRIPTION =
(ADDRESS_LIST =
(CONNECT_DATA =
(SID = CLRExtProc)
(PRESENTATION = RO)
any guess why it doesn’t work I tried many things, strangely it works fine with postgres but I’m guessing the problem is in oracle or in docker
here is how I run the image
podman run --network=host my-custom-image start-dev
Thanks in advance
