Configuration keycloak HA modele standalone-ha.xml
Start keycloak:
Started C:\Program Files\SAP\SAP Business One SLD Service\authentication\tools..\bin\standalone.bat -server-config=standalone-ha.xml -DJGROUPS_DISCOVERY_PROTOCOL=JDBC_PING -Djboss.node.name=node2 -DJGROUPS_DISCOVERY_EXTERNAL_IP=10.58.115.44 -Djboss.bind.address=0.0.0.0 for service B1CloudAuthentication in C:\Program Files\SAP\SAP Business One SLD Service\authentication\tools..\bin.
Actual Result:
Ramdom has error, Full log: server.log.
Restart service again, issue may gone.
2022-10-20 15:37:26,066 ERROR [org.jboss.msc.service.fail] (ServerService Thread Pool – 56) MSC000001: Failed to start service org.wildfly.clustering.jgroups.channel.ee: org.jboss.msc.service.StartException in service org.wildfly.clustering.jgroups.channel.ee: java.lang.IllegalStateException: java.lang.IllegalArgumentException: Could not lookup datasource java:jboss/datasources/KeycloakDS
at org.wildfly.clu…@26.1.0.Final//org.wildfly.clustering.service.FunctionalService.start(FunctionalService.java:66)
at org.wildfly.clu…@26.1.0.Final//org.wildfly.clustering.service.AsyncServiceConfigurator$AsyncService.lambda$start$0(AsyncServiceConfigurator.java:117)
at org.jbos…@2.4.0.Final//org.jboss.threads.ContextClassLoaderSavingRunnable.run(ContextClassLoaderSavingRunnable.java:35)
at org.jbos…@2.4.0.Final//org.jboss.threads.EnhancedQueueExecutor.safeRun(EnhancedQueueExecutor.java:1990)
at org.jbos…@2.4.0.Final//org.jboss.threads.EnhancedQueueExecutor$ThreadBody.doRunTask(EnhancedQueueExecutor.java:1486)
at org.jbos…@2.4.0.Final//org.jboss.threads.EnhancedQueueExecutor$ThreadBody.run(EnhancedQueueExecutor.java:1377)
at org.jbos…@2.4.0.Final//org.jboss.threads.JBossThread.run(JBossThread.java:513)
Caused by: java.lang.IllegalStateException: java.lang.IllegalArgumentException: Could not lookup datasource java:jboss/datasources/KeycloakDS
at org.jboss.as.cl…@26.1.0.Final//org.jboss.as.clustering.jgroups.subsystem.ChannelServiceConfigurator.get(ChannelServiceConfigurator.java:116)
at org.jboss.as.cl…@26.1.0.Final//org.jboss.as.clustering.jgroups.subsystem.ChannelServiceConfigurator.get(ChannelServiceConfigurator.java:58)
at org.wildfly.clu…@26.1.0.Final//org.wildfly.clustering.service.FunctionalService.start(FunctionalService.java:63)
… 7 more
Caused by: java.lang.IllegalArgumentException: Could not lookup datasource java:jboss/datasources/KeycloakDS
at org.jgroups//org.jgroups.protocols.JDBC_PING.getDataSourceFromJNDI(JDBC_PING.java:393)
at org.jgroups//org.jgroups.protocols.JDBC_PING.init(JDBC_PING.java:108)
at org.jgroups//org.jgroups.stack.ProtocolStack.initProtocolStack(ProtocolStack.java:854)
at org.jgroups//org.jgroups.stack.ProtocolStack.init(ProtocolStack.java:842)
at org.jgroups//org.jgroups.JChannel.(JChannel.java:164)
at org.jboss.as.cl…@26.1.0.Final//org.jboss.as.clustering.jgroups.JChannelFactory.createChannel(JChannelFactory.java:116)
at org.jboss.as.cl…@26.1.0.Final//org.jboss.as.clustering.jgroups.subsystem.ChannelServiceConfigurator.get(ChannelServiceConfigurator.java:96)
… 9 more
Caused by: javax.naming.NameNotFoundException: datasources/KeycloakDS [Root exception is java.lang.IllegalStateException]
at org.jboss…@26.1.0.Final//org.jboss.as.naming.ServiceBasedNamingStore.lookup(ServiceBasedNamingStore.java:152)
at org.jboss…@26.1.0.Final//org.jboss.as.naming.ServiceBasedNamingStore.lookup(ServiceBasedNamingStore.java:83)
at org.jboss…@26.1.0.Final//org.jboss.as.naming.NamingContext.lookup(NamingContext.java:207)
at org.jboss…@26.1.0.Final//org.jboss.as.naming.NamingContext.lookup(NamingContext.java:184)
at org.jboss…@26.1.0.Final//org.jboss.as.naming.InitialContext$DefaultInitialContext.lookup(InitialContext.java:239)
at org.jboss…@26.1.0.Final//org.jboss.as.naming.NamingContext.lookup(NamingContext.java:193)
at org.jboss…@26.1.0.Final//org.jboss.as.naming.NamingContext.lookup(NamingContext.java:189)
at java.naming/javax.naming.InitialContext.lookup(InitialContext.java:409)
at org.jgroups//org.jgroups.protocols.JDBC_PING.getDataSourceFromJNDI(JDBC_PING.java:384)
… 15 more
at org.jb…@1.4.13.Final//org.jboss.msc.value.InjectedValue.getValue(InjectedValue.java:50)
at org.jboss…@26.1.0.Final//org.jboss.as.naming.service.BinderService.getValue(BinderService.java:148)
at org.jboss…@26.1.0.Final//org.jboss.as.naming.service.BinderService.getValue(BinderService.java:46)
at org.jb…@1.4.13.Final//org.jboss.msc.service.ServiceControllerImpl.getValue(ServiceControllerImpl.java:1109)
at org.jboss…@26.1.0.Final//org.jboss.as.naming.ServiceBasedNamingStore.lookup(ServiceBasedNamingStore.java:130)
… 24 more
2022-10-20 15:37:26,095 INFO [org.jboss.as.connector.subsystems.datasources] (MSC service thread 1-1) WFLYJCA0001: Bound data source [java:jboss/datasources/KeycloakDS]
2022-10-20 15:37:26,101 INFO [org.wildfly.extension.undertow] (MSC service thread 1-4) WFLYUT0006: Undertow HTTPS listener https listening on 0.0.0.0:8464
2022-10-20 15:37:26,203 ERROR [org.jboss.as.controller.management-operation] (Controller Boot Thread) WFLYCTL0013: Operation (“add”) failed - address: ([
(“subsystem” => “jgroups”),
(“channel” => “ee”)
