I’m troubleshooting some issues with data being gone after my dockerized Keycloak instance is removed and I suspect a misconfiguration on my side. For troubleshooting purposes I have changed my
- DB_ADDR=postgresql
to something non existent:
- DB_ADDR=asjlkasfasffga
and the Keycloak container starts without issues but more important, it doesn’t output any errors regarding the database connection. Is this expected? I’m was expecting to see something along the lines of “could not connect to db” or similar. The Postgres bind mount does exist and gets filled with (default) data when the Postgres container is started. Postgres also doesn’t throw out any errors when it’s started.
Docker compose file:
services:
postgresql:
image: postgresql:latest
environment:
- POSTGRES_USER=keycloakdbuser
- POSTGRES_PASSWORD=password
- POSTGRES_DB=keycloak
volumes:
- /opt/project/postgresql:/var/lib/postgresql/data
networks:
- keycloaknet
keycloak:
image: quay.io/keycloak/keycloak:latest
ports:
- 8080:8080
environment:
- KEYCLOAK_ADMIN=keycloakadmin
- KEYCLOAK_ADMIN_PASSWORD=adminpassword
- DB_DATABASE=keycloak
- DB_USER=keycloakdbuser
- DB_PASSWORD=password
- DB_VENDOR=postgres
entrypoint: '/opt/keycloak/bin/kc.sh --spi-login-protocol-openid-connect-legacy-logout-redirect-uri=true --spi-theme-static-max-age=-1 --spi-theme-cache-themes=false --spi-theme-cache-templates=false start --hostname hostname.tld'
networks:
- keycloaknet
depends_on:
- postgresql
keycloaknet:
driver: bridge
