Hi
I have configured Infinispan Cluster version 14.0 with Keycloak version 21.0.2-debian-11-r0 on EKS Cluster.
When I bring up Keycloak, I am seeing below error:
org.infinispan.commons.dataconversion.EncodingException: ISPN000492: Cannot find transcoder between 'application/x-protostream' to 'application/x-jboss-marshalling'
Infinispan config:
apiVersion: v1
data:
infinispan.yml: |-
infinispan:
cacheContainer:
caches:
actionTokens:
distributedCache:
encoding:
key:
mediaType: application/x-jboss-marshalling
value:
expiration:
interval: 300000
max-idle: "-1"
memory:
max-count: "-1"
mode: SYNC
owners: 2
statistics: "true"
authenticationSessions:
distributedCache:
encoding:
key:
value:
mode: SYNC
owners: "2"
statistics: "true"
clientSessions:
distributedCache:
encoding:
key:
value:
mode: SYNC
owners: 2
statistics: "true"
distributed-cache-cfg:
distributedCacheConfiguration:
encoding:
expiration:
lifespan: "900000000000000000"
loginFailures:
distributedCache:
configuration: distributed-cache-cfg
owners: 2
offlineClientSessions:
distributedCache:
owners: 2
offlineSessions:
distributedCache:
owners: 2
realms:
replicatedCache:
encoding:
key:
value:
locking:
acquireTimeout: "15000"
concurrencyLevel: "1000"
isolation: REPEATABLE_READ
mode: SYNC
stateTransfer:
timeout: "60000"
statistics: "true"
replicated-cache-cfg:
replicatedCacheConfiguration:
encoding:
sessions:
distributedCache:
owners: 2
users:
replicatedCache:
encoding:
key:
value:
locking:
mode: SYNC
stateTransfer:
timeout: "60000"
statistics: "true"
work:
replicatedCache:
configuration: replicated-cache-cfg
security:
authorization: {}
statistics: "true"
transport:
cluster: ${infinispan.cluster.name:cluster}
node-name: ${infinispan.node.name:}
stack: kubernetes
server:
endpoints:
- connectors:
hotrod:
hotrodConnector: null
rest:
restConnector: null
securityRealm: default
socketBinding: default
- connectors:
rest:
restConnector:
authentication:
mechanisms: BASIC
securityRealm: metrics
socketBinding: metrics
interfaces:
- inetAddress:
value: ${infinispan.bind.address:127.0.0.1}
security:
credentialStores:
- clearTextCredential:
clearText: secret
path: credentials.pfx
securityRealms:
- name: default
propertiesRealm:
groupProperties:
path: groups.properties
groupsAttribute: Roles
userProperties:
path: users.properties
- name: metrics
propertiesRealm:
groupProperties:
path: metrics-groups.properties
relativeTo: infinispan.server.config.path
userProperties:
path: metrics-users.properties
socketBindings:
defaultInterface: public
portOffset: ${infinispan.socket.binding.port-offset:0}
socketBinding:
- name: default
port: 11222
- name: metrics
port: 11223
log4j2.xml: |-
<Configuration name="InfinispanServerConfig" monitorInterval="60" shutdownHook="disable">
<Properties>
<Property name="path">${sys:infinispan.server.log.path}</Property>
<Property name="accessLogPattern">%X{address} %X{user} [%d{dd/MMM/yyyy:HH:mm:ss Z}] "%X{method} %m %X{protocol}" %X{status} %X{requestSize} %X{responseSize} %X{duration}%n</Property>
</Properties>
<Appenders>
<!-- Colored output on the console -->
<Console name="STDOUT">
<PatternLayout pattern="%highlight{%d{yyyy-MM-dd HH:mm:ss,SSS} %-5p (%t) [%c] %m%throwable}{INFO=normal, DEBUG=normal, TRACE=normal}%n"/>
</Console>
<!-- Rolling file -->
<RollingFile name="FILE" createOnDemand="true"
fileName="${path}/server.log"
filePattern="${path}/server.log.%d{yyyy-MM-dd}-%i">
<Policies>
<OnStartupTriggeringPolicy />
<SizeBasedTriggeringPolicy size="100 MB" />
<TimeBasedTriggeringPolicy />
</Policies>
<PatternLayout pattern="%d{yyyy-MM-dd HH:mm:ss,SSS} %-5p (%t) [%c] %m%throwable%n"/>
</RollingFile>
<RollingFile name="AUDIT-FILE" createOnDemand="true"
fileName="${path}/audit.log"
filePattern="${path}/audit.log.%d{yyyy-MM-dd}-%i">
<Policies>
</Policies>
<PatternLayout pattern="%d{yyyy-MM-dd HH:mm:ss,SSS} %m%n"/>
</RollingFile>
<!-- Rolling JSON file, disabled by default -->
<RollingFile name="JSON-FILE" createOnDemand="true"
fileName="${path}/server.log.json"
filePattern="${path}/server.log.json.%d{yyyy-MM-dd}-%i">
<Policies>
</Policies>
<JsonLayout compact="true" eventEol="true" stacktraceAsString="true">
<KeyValuePair key="time" value="$${date:yyyy-MM-dd'T'HH:mm:ss.SSSZ}" />
</JsonLayout>
</RollingFile>
<!-- Rolling HotRod access log, disabled by default -->
<RollingFile name="HR-ACCESS-FILE" createOnDemand="true"
fileName="${path}/hotrod-access.log"
filePattern="${path}/hotrod-access.log.%i">
<Policies>
</Policies>
<PatternLayout pattern="${accessLogPattern}"/>
</RollingFile>
<!-- Rolling REST access log, disabled by default -->
<RollingFile name="REST-ACCESS-FILE" createOnDemand="true"
fileName="${path}/rest-access.log"
filePattern="${path}/rest-access.log.%i">
<Policies>
</Policies>
</RollingFile>
</Appenders>
<Loggers>
<Root level="INFO">
<AppenderRef ref="STDOUT"/>
<!-- Uncomment just one of the two lines bellow to use alternatively JSON logging or plain-text logging to file-->
<AppenderRef ref="FILE"/>
<!-- <AppenderRef ref="JSON-FILE"/>-->
</Root>
<!-- Set to INFO to enable audit logging -->
<Logger name="org.infinispan.AUDIT" additivity="false" level="ERROR">
<AppenderRef ref="AUDIT-FILE"/>
</Logger>
<!-- Set to TRACE to enable access logging for Hot Rod requests -->
<Logger name="org.infinispan.HOTROD_ACCESS_LOG" additivity="false" level="INFO">
<AppenderRef ref="HR-ACCESS-FILE"/>
</Logger>
<!-- Set to TRACE to enable access logging for REST requests -->
<Logger name="org.infinispan.REST_ACCESS_LOG" additivity="false" level="INFO">
<AppenderRef ref="REST-ACCESS-FILE"/>
</Logger>
<Logger name="com.arjuna" level="WARN" />
<Logger name="io.netty.handler.ssl.ApplicationProtocolNegotiationHandler" level="ERROR" />
</Loggers>
</Configuration>
Content of ispn-cache.xml
<infinispan
xsi:schemaLocation="urn:infinispan:config:14.0 http://www.infinispan.org/schemas/infinispan-config-13.0.xsd"
xmlns="urn:infinispan:config:14.0">
<transport lock-timeout="60000"/>
<replicated-cache name="realms">
<expiration lifespan="-1"/>
<remote-store cache="realms" xmlns="urn:infinispan:config:store:remote:14.0"
purge="false"
preload="false"
shared="true" segmented="false"
connect-timeout="${env.KEYCLOAK_REMOTE_ISPN_CONN_TIMEOUT:2000}">
<remote-server host="${env.INFINISPAN_SERVER}" port="${infinispan.bind.port:11222}"/>
<security>
<authentication>
<!-- <plain username="${env.KEYCLOAK_REMOTE_ISPN_USERNAME:keycloak}"-->
<!-- password="${env.KEYCLOAK_REMOTE_ISPN_PASSWORD:password}"-->
<digest username="${env.KEYCLOAK_REMOTE_ISPN_USERNAME:keycloak}"
realm="default"/>
</authentication>
</security>
<property name="rawValues">true</property>
<property name="marshaller">org.keycloak.cluster.infinispan.KeycloakHotRodMarshallerFactory</property>
</remote-store>
</replicated-cache>
<local-cache name="users">
<encoding>
<key media-type="application/x-jboss-marshalling"/>
<value media-type="application/x-jboss-marshalling"/>
</encoding>
<memory max-count="10000"/>
</local-cache>
<local-cache name="keys">
<encoding>
</encoding>
<memory max-count="1000"/>
</local-cache>
<encoding>
</encoding>
</local-cache>
<remote-store cache="sessions" xmlns="urn:infinispan:config:store:remote:14.0"
purge="false"
preload="false"
<security>
<authentication>
realm="default"/>
</authentication>
</security>
</remote-store>
</distributed-cache>
<remote-store cache="offlineSessions" xmlns="urn:infinispan:config:store:remote:14.0"
purge="false"
preload="false"
<security>
<authentication>
realm="default"/>
</authentication>
</security>
</remote-store>
<remote-store cache="clientSessions" xmlns="urn:infinispan:config:store:remote:14.0"
purge="false"
preload="false"
<security>
<authentication>
realm="default"/>
</authentication>
</security>
</remote-store>
<remote-store cache="offlineClientSessions" xmlns="urn:infinispan:config:store:remote:14.0"
purge="false"
preload="false"
<security>
<authentication>
realm="default"/>
</authentication>
</security>
</remote-store>
<remote-store cache="loginFailures" xmlns="urn:infinispan:config:store:remote:14.0"
purge="false"
preload="false"
<security>
<authentication>
realm="default"/>
</authentication>
</security>
</remote-store>
<remote-store cache="work" xmlns="urn:infinispan:config:store:remote:14.0"
purge="false"
preload="false"
<security>
<authentication>
realm="default"/>
</authentication>
</security>
</remote-store>
</replicated-cache>
<encoding>
</encoding>
<memory max-count="-1"/>
<remote-store cache="actionTokens" xmlns="urn:infinispan:config:store:remote:14.0"
purge="false"
preload="false"
<security>
<authentication>
realm="default"/>
</authentication>
</security>
</remote-store>
</cache-container>
</infinispan>
What can be the issue here?
