I am looking to set up Keycloak through Docker as one of many services in a monorepo.
It looks like in previous versions it was possible to import a realm when Keycloak boots up but from what I can see in this Github issue that’s no longer supported.
Here is what I’m trying to achieve:
- When developing locally I want to be able to spin up a container where Keycloak has an identical configuration to production.
- When I deploy to production for the first time I want to be able to set up a realm programatically.
- On subsequent deploys it would ignore the import (as it’s already been done) but ideally it would be possible to apply a migration if there’s a need for any changes.
Here’s the relevant section from my docker-compose.yml
auth:
build:
context: auth
depends_on:
db-auth:
condition: service_started
nginx-proxy:
ports:
- "3001:8080"
environment:
KC_DB_ADDR: db-auth
KC_DB_USERNAME: "postgres"
KC_DB_PASSWORD: ${POSTGRES_PASSWORD}
KC_HOSTNAME: auth.app.local
KEYCLOAK_ADMIN: admin
KEYCLOAK_ADMIN_PASSWORD: ${KEYCLOAK_ADMIN_PASSWORD}
KEYCLOAK_IMPORT: /opt/keycloak/imports/test-realm.json -Dkeycloak.profile.feature.upload_scripts=enabled
restart: always
command: start # for prod it also needs "--server-config=standalone-ha.xml"
volumes:
- "./auth/config:/opt/keycloak/imports"
networks:
- app-network
My Dockerfile is setup like this:
FROM quay.io/keycloak/keycloak:latest AS builder
# Various bits of config
COPY --from=builder /opt/keycloak/ /opt/keycloak/
# ... More config
ENTRYPOINT ["/opt/keycloak/bin/kc.sh"]
Nothing I tried worked to run my import file. That’s when I discovered that Github issue above.
If anyone can provide some advice it would be much appreciated.
