I’m trying to evaluate Keycloak-17.0.0
When I access account console with the below URL
https://<domain-name>/realms/<realm-name>/account/
the account console just shows a loader like this.
Browser console reports the below error
https://<domain-name>/js/keycloak.js net::ERR_ABORTED 404 (Not Found)
Uncaught ReferenceError: Keycloak is not defined at (index):125:28
I’m running Keycloak-17.0.0 on JDK11 (Eclipse Adoptitum Temurin 11.0.14) behind a Nginx proxy.
Below is my keycloak configuration.
# The proxy address forwarding mode if the server is behind a reverse proxy.
proxy=passthrough
# Hostname for the Keycloak server.
hostname=<domain-name>
# Hostname for the Keycloak server admin console.
hostname-admin=<admin-domain-name>
hostname-strict-backchannel=true
I have tried with proxy
value set to edge
and passthrough
Below is my nginx proxy configuration.
server {
server_name <admin-domain-name>;
access_log /var/log/nginx/keycloak-mgmt-access.log main;
error_log /var/log/nginx/keycloak-mgmt-error.log;
# ============= Proxy Configuration ============= #
location / {
proxy_pass_request_headers on;
proxy_pass http://localhost:8080;
# //============ SSL Settings =============== //
server {
server_name <domain-name>;
access_log /var/log/nginx/keycloak-access.log main;
error_log /var/log/nginx/keycloak-error.log;
location /realms/ {
location /resources/ {
server {
if ($host = <domain-name>) {
return 301 https://$host$request_uri;
listen 80;
return 404;
}server {
if ($host = <admin-domain-name>) {
listen 80;
return 404;
Came across couple of old similar issues but that involved modifying the frontendUrl
or updating the Web origin
with +
but it doesn’t seem to be relevant for or working for quarkus distributions.
Not sure what I’m missing. Any help would be much appreciated.
