Keycloak is running in k8s, behind a reverse proxy.
Commands with which the application is started:
command:
- /opt/keycloak/bin/kc.sh
- --verbose
- start
- --proxy=edge
- --http-relative-path /tri/auth
- --hostname-strict=false
- --hostname-strict-https=false
- --http-enabled=true
ingress rule:
kind: Ingress
metadata:
namespace: tri-dev
annotations:
kubernetes.io/ingress.class: nginx
nginx.ingress.kubernetes.io/proxy-buffer-size: 128k
spec:
rules:
- host: tri-dev-proxy.example.com
http:
paths:
- path: /tri/auth/
pathType: Prefix
backend:
service:
port:
number: 80
config proxy:
location /tri/ {
proxy_pass http://kube-node-ingress-upstream-80;
proxy_set_header Host $host;
proxy_set_header X-Forwarded-Server $host;
cat /etc/nginx/upstream.d/kube.upstream.conf
upstream kube-node-ingress-upstream-80 {
server tri-dev-kube-node-1.priv:80;
server tri-dev-kube-node-2.priv:80;
server tri-dev-kube-node-3.priv:80;
https://tri-dev-proxy.example.com/tri/auth/ - the start page is available at this URL, but when you go to the admin console, it redirects to http (http://tri-dev-proxy.example.com/tri/auth/admin/), page not available.
In the ingress controller logs, the response is 200, when I go to the start page, they are not there when I enter the admin panel:
10.208.38.11 - - [01/Dec/2022:06:40:41 +0000] "GET /tri/auth/resources/g95ve/welcome/keycloak/logo.png HTTP/1.0" 200 7539 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/107.0.0.0 Safari/537.36" 775 0.016 [tri-dev-tri-keycloak-20-http-80] [] 10.233.104.232:8080 7539 0.016 200 12ed1e9084c4958620495cc04c817f99
10.208.38.11 - - [01/Dec/2022:06:40:41 +0000] "GET /tri/auth/resources/g95ve/welcome/keycloak/img/favicon.ico HTTP/1.0" 200 650 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/107.0.0.0 Safari/537.36" 782 0.006 [tri-dev-tri-keycloak-20-http-80] [] 10.233.104.232:8080 650 0.008 200 315323245937fb56f6b7cb6cfe91f560
Please tell me where is the mistake.
