Im using keycloak Keycloak 20.0.5 with infinispan 14.0.21.Final and using docker compose setup is currently working without issue but im getting below warning from infinispan container once keycloak is connected to infinispan container.sometimes it’s not getting if i restart the infinispan container.Does anyone know about this?
WARN (non-blocking-thread--p2-t3) [org.infinispan.server.hotrod.Encoder2x] ISPN028029: Client /172.18.0.3:11222 keeps providing outdated topology -1
infinispan.xml
<infinispan
xsi:schemaLocation="urn:infinispan:config:13.0 https://infinispan.org/schemas/infinispan-config-13.0.xsd
urn:infinispan:server:13.0 https://infinispan.org/schemas/infinispan-server-13.0.xsd"
xmlns="urn:infinispan:config:13.0"
xmlns:server="urn:infinispan:server:13.0">
<cache-container name="keycloak" statistics="true">
<transport cluster="${infinispan.cluster.name:ISPN}" stack="${infinispan.cluster.stack:tcp}" node-name="${infinispan.node.name:}"/>
<security>
<authorization/>
</security>
<serialization marshaller="org.infinispan.jboss.marshalling.commons.GenericJBossMarshaller">
<allow-list>
<class>org.keycloak.cluster.infinispan.WrapperClusterEvent</class>
<regex>.*</regex>
</allow-list>
</serialization>
<transaction mode="NON_XA" locking="PESSIMISTIC"/>
<encoding media-type="application/x-jboss-marshalling"/>
</replicated-cache>
<distributed-cache name="sessions">
</distributed-cache>
<distributed-cache name="authenticationSessions">
<distributed-cache name="clientSessions">
<distributed-cache name="offlineSessions">
<distributed-cache name="offlineClientSessions">
<distributed-cache name="actionTokens">
<distributed-cache name="loginFailures">
<encoding media-type="text/plain"/>
</cache-container>
<server xmlns="urn:infinispan:server:13.0">
<interfaces>
<interface name="public">
<inet-address value="${infinispan.bind.address:127.0.0.1}"/>
</interface>
</interfaces>
<socket-bindings default-interface="public" port-offset="${infinispan.socket.binding.port-offset:0}">
<socket-binding name="default" port="${infinispan.bind.port:11222}"/>
<socket-binding name="memcached" port="11221"/>
</socket-bindings>
<security>
<credential-stores>
<credential-store name="credentials" path="credentials.pfx">
<clear-text-credential clear-text="secret"/>
</credential-store>
</credential-stores>
<security-realms>
<security-realm name="default">
<!-- Uncomment to enable TLS on the realm -->
<!-- server-identities>
<ssl>
<keystore path="application.keystore"
password="password" alias="server"
generate-self-signed-certificate-host="localhost"/>
</ssl>
</server-identities-->
<properties-realm groups-attribute="Roles">
<user-properties path="users.properties"/>
<group-properties path="groups.properties"/>
</properties-realm>
</security-realm>
</security-realms>
</security>
<endpoints socket-binding="default" security-realm="default" />
</server>
</infinispan>
cache-ispn.xml for keycloak
<infinispan
xsi:schemaLocation="urn:infinispan:config:13.0 http://www.infinispan.org/schemas/infinispan-config-13.0.xsd"
xmlns="urn:infinispan:config:13.0">
<transport cluster="${infinispan.cluster.name:ISPN}" stack="tcp" lock-timeout="60000" site="site1"/>
<local-cache name="realms">
<encoding>
</encoding>
<memory max-count="10000"/>
</local-cache>
<local-cache name="users">
<encoding>
</encoding>
</local-cache>
<encoding>
</encoding>
</local-cache>
<local-cache name="keys">
<encoding>
</encoding>
<memory max-count="1000"/>
</local-cache>
<remote-store xmlns="urn:infinispan:config:store:remote:13.0"
cache="sessions"
purge="false"
preload="false"
segmented="false"
shared="true"
raw-values="true"
marshaller="org.keycloak.cluster.infinispan.KeycloakHotRodMarshallerFactory">
<remote-server host="${env.INFINISPAN_HOST}" port="11222" />
<security>
<authentication server-name="infinispan">
<digest username="admin" password="admin" realm="default"/>
</authentication>
</security>
</remote-store>
cache="authenticationSessions"
purge="false"
preload="false"
segmented="false"
shared="true"
raw-values="true"
<security>
</authentication>
</security>
</remote-store>
cache="offlineSessions"
purge="false"
preload="false"
segmented="false"
shared="true"
raw-values="true"
<security>
</authentication>
</security>
</remote-store>
cache="clientSessions"
purge="false"
preload="false"
segmented="false"
shared="true"
raw-values="true"
<security>
</authentication>
</security>
</remote-store>
cache="offlineClientSessions"
purge="false"
preload="false"
segmented="false"
shared="true"
raw-values="true"
<security>
</authentication>
</security>
</remote-store>
cache="loginFailures"
purge="false"
preload="false"
segmented="false"
shared="true"
raw-values="false"
<security>
</authentication>
</security>
</remote-store>
<expiration max-idle="-1" interval="300000"/>
cache="actionTokens"
purge="false"
preload="false"
segmented="false"
shared="true"
raw-values="true"
<security>
</authentication>
</security>
</remote-store>
cache="work"
purge="false"
preload="false"
segmented="false"
shared="true"
raw-values="true"
<security>
</authentication>
</security>
</remote-store>
</replicated-cache>
</cache-container>
</infinispan>
