Hi Team,
I have tried the following Docker image and ec2 container for 23.0.4 and I getting “page not found” page when trying to start keycloak.
Please find and check the below details and help me to resolve it. Thank You!
I read the documentation for creating docker, but I do not get it to work for me.
Docker File:
FROM public.ecr.aws/docker/library/maven:3.8.7-openjdk-18-slim as maven-builder
COPY native-s3-pom.xml ./
RUN mvn package -f native-s3-pom.xml
FROM Quay as keycloak-builder
ENV KC_HEALTH_ENABLED=true
ENV KC_METRICS_ENABLED=true
ENV KC_DB=mysql
ENV KC_FEATURES=preview,token-exchange,admin-fine-grained-authz
ENV KC_CACHE_STACK=ec2
ENV KC_HTTP_RELATIVE_PATH=/auth
ENV PROXY_ADDRESS_FORWARDING=true
ENV KC_HTTP_ENABLED=true
ENV KC_PROXY=edge
FROM Quay
COPY --from=keycloak-builder /opt/keycloak/lib/quarkus/ /opt/keycloak/lib/quarkus/
COPY --from=keycloak-builder /opt/keycloak/providers/* /opt/keycloak/providers/
COPY themes /opt/keycloak/themes/
COPY keycloak.conf /opt/keycloak/conf/
WORKDIR /opt/keycloak
RUN /opt/keycloak/bin/kc.sh show-config
ENV KC_DB=mysql
ENV KC_DB_URL=<url?
ENV KC_DB_USERNAME=
ENV KC_DB_PASSWORD=
ENV KC_HOSTNAME=mydomain.com
ENV KC_HOSTNAME_STRICT=false
ENTRYPOINT [“/opt/keycloak/bin/kc.sh” , “start-dev” , “–hostname-strict-https=false”]
EXPOSE 22 8080 8443 9990 9993 7800
Logs:
January 29, 2024 at 12:27 (UTC+5:30) at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:420) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at io.netty.channel.DefaultChannelPipeline.fireChannelRead(DefaultChannelPipeline.java:919) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at io.netty.channel.nio.AbstractNioByteChannel$NioByteUnsafe.read(AbstractNioByteChannel.java:166) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at io.netty.channel.nio.NioEventLoop.processSelectedKey(NioEventLoop.java:788) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at io.netty.channel.nio.NioEventLoop.processSelectedKeysOptimized(NioEventLoop.java:724) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at io.netty.channel.nio.NioEventLoop.processSelectedKeys(NioEventLoop.java:650) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:562) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at io.netty.util.concurrent.SingleThreadEventExecutor$4.run(SingleThreadEventExecutor.java:997) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at io.netty.util.internal.ThreadExecutorMap$2.run(ThreadExecutorMap.java:74) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at io.netty.util.concurrent.FastThreadLocalRunnable.run(FastThreadLocalRunnable.java:30) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at java.base@17.0.10/java.lang.Thread.run(Thread.java:840) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) 2024-01-29 06:57:36,190 WARN [io.vertx.core.impl.BlockedThreadChecker] (vertx-blocked-thread-checker) Thread Thread[vert.x-eventloop-thread-0,5,main] has been blocked for 2201 ms, time limit is 2000 ms: io.vertx.core.VertxException: Thread blocked KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at org.keycloak.theme.KeycloakSanitizerMethod.exec(KeycloakSanitizerMethod.java:47) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at freemarker.core.MethodCall._eval(MethodCall.java:62) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at freemarker.core.Expression.eval(Expression.java:101) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at freemarker.core.BuiltInsForOutputFormatRelated$AbstractConverterBI.calculateResult(BuiltInsForOutputFormatRelated.java:50) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at freemarker.core.MarkupOutputFormatBoundBuiltIn._eval(MarkupOutputFormatBoundBuiltIn.java:40) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at freemarker.core.DollarVariable.calculateInterpolatedStringOrMarkup(DollarVariable.java:104) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at freemarker.core.DollarVariable.accept(DollarVariable.java:63) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at freemarker.core.Environment.visit(Environment.java:371) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at freemarker.core.Environment.invokeMacroOrFunctionCommonPart(Environment.java:877) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at freemarker.core.Environment.invokeMacro(Environment.java:813) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at freemarker.core.UnifiedCall.accept(UnifiedCall.java:84) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at freemarker.core.Environment.visit(Environment.java:335) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at freemarker.core.Environment.visit(Environment.java:341) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at freemarker.core.Environment.process(Environment.java:314) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at freemarker.template.Template.process(Template.java:383) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at org.keycloak.theme.freemarker.DefaultFreeMarkerProvider.processTemplate(DefaultFreeMarkerProvider.java:49) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at org.keycloak.services.error.KeycloakErrorHandler.getResponse(KeycloakErrorHandler.java:107) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at org.keycloak.services.error.KeycloakErrorHandler$1.run(KeycloakErrorHandler.java:62) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at org.keycloak.services.error.KeycloakErrorHandler$1.run(KeycloakErrorHandler.java:59) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at org.keycloak.models.utils.KeycloakModelUtils.runJobInTransactionWithResult(KeycloakModelUtils.java:382) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at org.keycloak.models.utils.KeycloakModelUtils.runJobInTransactionWithResult(KeycloakModelUtils.java:365) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at org.keycloak.services.error.KeycloakErrorHandler.toResponse(KeycloakErrorHandler.java:58) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at org.jboss.resteasy.reactive.server.core.RuntimeExceptionMapper.mapException(RuntimeExceptionMapper.java:99) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at org.jboss.resteasy.reactive.server.core.ResteasyReactiveRequestContext.mapExceptionIfPresent(ResteasyReactiveRequestContext.java:337) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at org.jboss.resteasy.reactive.server.handlers.ExceptionHandler.handle(ExceptionHandler.java:15) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at io.quarkus.resteasy.reactive.server.runtime.QuarkusResteasyReactiveRequestContext.invokeHandler(QuarkusResteasyReactiveRequestContext.java:150) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at org.jboss.resteasy.reactive.common.core.AbstractResteasyReactiveContext.run(AbstractResteasyReactiveContext.java:145) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at org.jboss.resteasy.reactive.server.handlers.RestInitialHandler.beginProcessing(RestInitialHandler.java:48) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at org.jboss.resteasy.reactive.server.vertx.ResteasyReactiveVertxHandler.handle(ResteasyReactiveVertxHandler.java:23) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at org.jboss.resteasy.reactive.server.vertx.ResteasyReactiveVertxHandler.handle(ResteasyReactiveVertxHandler.java:10) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at io.vertx.ext.web.impl.RouteState.handleContext(RouteState.java:1286) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at io.vertx.ext.web.impl.RoutingContextImplBase.iterateNext(RoutingContextImplBase.java:177) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at io.vertx.ext.web.impl.RoutingContextImpl.next(RoutingContextImpl.java:144) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at io.quarkus.vertx.http.runtime.options.HttpServerCommonHandlers$1.handle(HttpServerCommonHandlers.java:58) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at io.quarkus.vertx.http.runtime.options.HttpServerCommonHandlers$1.handle(HttpServerCommonHandlers.java:36) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at io.quarkus.resteasy.reactive.server.runtime.ResteasyReactiveRecorder$13.handle(ResteasyReactiveRecorder.java:382) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at io.quarkus.resteasy.reactive.server.runtime.ResteasyReactiveRecorder$13.handle(ResteasyReactiveRecorder.java:375) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at io.vertx.ext.web.impl.RouterImpl.handle(RouterImpl.java:68) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at io.vertx.ext.web.impl.RouterImpl.handle(RouterImpl.java:37) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at io.quarkus.vertx.http.runtime.options.HttpServerCommonHandlers$3.handle(HttpServerCommonHandlers.java:99) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at io.quarkus.vertx.http.runtime.options.HttpServerCommonHandlers$3.handle(HttpServerCommonHandlers.java:96) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at io.quarkus.vertx.http.runtime.options.HttpServerCommonHandlers$2.handle(HttpServerCommonHandlers.java:82) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at io.quarkus.vertx.http.runtime.options.HttpServerCommonHandlers$2.handle(HttpServerCommonHandlers.java:65) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at io.quarkus.vertx.http.runtime.VertxHttpRecorder$1.handle(VertxHttpRecorder.java:177) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at io.quarkus.vertx.http.runtime.VertxHttpRecorder$1.handle(VertxHttpRecorder.java:153) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at io.vertx.core.impl.EventLoopContext.emit(EventLoopContext.java:55) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at io.vertx.core.impl.DuplicatedContext.emit(DuplicatedContext.java:179) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at io.vertx.core.http.impl.Http1xServerConnection.handleMessage(Http1xServerConnection.java:174) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at io.vertx.core.net.impl.ConnectionBase.read(ConnectionBase.java:159) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at io.vertx.core.net.impl.VertxHandler.channelRead(VertxHandler.java:153) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:442) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at io.netty.channel.AbstractChannelHandlerContext.fireChannelRead(AbstractChannelHandlerContext.java:412) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at io.vertx.core.http.impl.Http1xUpgradeToH2CHandler.channelRead(Http1xUpgradeToH2CHandler.java:124) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:444) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at io.netty.handler.timeout.IdleStateHandler.channelRead(IdleStateHandler.java:286) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at io.netty.handler.codec.ByteToMessageDecoder.fireChannelRead(ByteToMessageDecoder.java:346) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at io.netty.handler.codec.ByteToMessageDecoder.channelRead(ByteToMessageDecoder.java:318) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at io.vertx.core.http.impl.Http1xOrH2CHandler.end(Http1xOrH2CHandler.java:61) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at io.vertx.core.http.impl.Http1xOrH2CHandler.channelRead(Http1xOrH2CHandler.java:38) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at io.netty.channel.DefaultChannelPipeline$HeadContext.channelRead(DefaultChannelPipeline.java:1410) KC-Cache-Upgrade
January 29, 2024 at 12:27 (UTC+5:30) at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:440) KC-Cache-Upgrade
January 29, 2024 at 12:26 (UTC+5:30) 2024-01-29 06:56:37,098 WARN [org.keycloak.quarkus.runtime.KeycloakMain] (main) Running the server in development mode. DO NOT use this configuration in production. KC-Cache-Upgrade
January 29, 2024 at 12:26 (UTC+5:30) 2024-01-29 06:56:37,092 INFO [io.quarkus] (main) Profile dev activated. KC-Cache-Upgrade
