Need urgent Help
I have a keycloak docker container. I did nginx proxy configuration for keycloak. When i try to login to admin console, it keeps going in infinite loop. below is the detail:
docker compose:
version: ‘3.9’
services:
jboss-keycloak-server:
image: jboss/keycloak
container_name: jboss-keycloak-server
expose:
- 8081
environment:
KEYCLOAK_USER: epadmin
KEYCLOAK_PASSWORD: admin
KEYCLOAK_IMPORT: /tmp/import.json
DB_VENDOR: postgres
DB_SCHEMA: public
DB_DATABASE: postgres
DB_USER: postgres
DB_PASSWORD: password
DB_ADDR: identity-db
DB_PORT: 9000
ACCOUNT_SID: $ACCOUNT_SID
AUTH_TOKEN: $AUTH_TOKEN
TRIAL_NUMBER: $TRIAL_NUMBER
KEYCLOAK_SMS_AUTHENTICATOR: $KEYCLOAK_SMS_AUTHENTICATOR
KEYCLOAK_SMS_AUTHENTICATOR_ID: $KEYCLOAK_SMS_AUTHENTICATOR_ID
KEYCLOAK_FRONTEND_URL: https:///auth/
KC_PROXY_ADDRESS_FORWARDING: “true”
KC_HOSTNAME_STRICT: “false”
KC_TRANSACTION_XA_ENABLED: “false”
KC_HOSTNAME_STRICT_HTTPS: “false”
#KC_HTTP_RELATIVE_PATH: “/auth”
KC_PROXY: edge
#PROXY_ADDRESS_FORWARDING: passthrough
ports:
- 8081:8080
volumes:
# - ./deployments:/opt/jboss/keycloak/standalone/deployments
- ./imports/import-realm.json:/tmp/import.json
nginx configuraiton:
server {
listen 8084;
listen [::]:8084;
server_name <domain-name>;
location / {
proxy_http_version 1.1;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection 'upgrade';
#proxy_set_header Host $host;
#proxy_set_header X-Forwarded-For $remote_addr;
#proxy_set_header X-Real-IP $remote_addr;
proxy_cache_bypass $http_upgrade;
add_header Access-Control-Allow-Origin *;
proxy_pass http://keycloak:8081/;
proxy_ssl_verify off;
proxy_set_header X-Forwarded-Server $host;
keycloak version
bash-4.4$ ./standalone.sh --version
JBoss Bootstrap Environment
JBOSS_HOME: /opt/jboss/keycloak
JAVA: java
JAVA_OPTS: -server -Xms64m -Xmx512m -XX:MetaspaceSize=96M -XX:MaxMetaspaceSize=256m -Djava.net.preferIPv4Stack=true -Djboss.modules.system.pkgs=org.jboss.byteman -Djava.awt.headless=true --add-exports=java.desktop/sun.awt=ALL-UNNAMED --add-exports=java.naming/com.sun.jndi.ldap=ALL-UNNAMED --add-opens=java.base/java.lang=ALL-UNNAMED --add-opens=java.base/java.lang.invoke=ALL-UNNAMED --add-opens=java.base/java.lang.reflect=ALL-UNNAMED --add-opens=java.base/java.io=ALL-UNNAMED --add-opens=java.base/java.security=ALL-UNNAMED --add-opens=java.base/java.util=ALL-UNNAMED --add-opens=java.base/java.util.concurrent=ALL-UNNAMED --add-opens=java.management/javax.management=ALL-UNNAMED --add-opens=java.naming/javax.naming=ALL-UNNAMED
12:34:31,758 INFO [org.jboss.modules] (main) JBoss Modules version 2.0.0.Final
Keycloak 16.1.1 (WildFly Core 18.0.4.Final)
