I’m running mu keycloak on top Kubernetes.
In order to add a customized object, I need to update the configuration file. I have noticed that during startup there are script that updating the configuration – example of a command taken from the script :
/subsystem=datasources/data-source=KeycloakDS: write-attribute(name=user-name, value=${env.DB_USER:keycloak})
For my customized object, I need to add an additional provider (demo - the second provider) under the following structure. Can you please suggest how I should define the command?
Thanks
>"<subsystem xmlns="urn:jboss:domain:keycloak-server:1.1">
> <web-context>auth</web-context>
> <providers>
> <provider>classpath:${jboss.home.dir}/providers/*</provider>
> <provider>module:demo.keycloak.organizations.demo-organizations-mapper</provider>
> </providers>
> <master-realm-name>master</master-realm-name>
