I want to test a minor code change into both the admin-ui and the server code (specifically to the LDAP user federation provider).
I see that when I build the server, it downloads the admin-ui. How can I use the admin-ui I am working with instead?
And is there a way or is it worth it to use Eclipse to develop with? As I said, the code is very small - not more than 20 lines all together, but I just want to have an easy way to test and debug while writing the code.
I have experience with Java, but not so much with maven or such a huge project, so if anyone could give me some pointer on how to setup a development environment, I’d be very grateful.
