I am using Minikube to run it locally, and when I inspect my pods, I get the output which indicates that the Status of my keycloak pod is CrashLoopBackOff.
How can I get rid of this status?
I even tried running kubectl <POD_NAME> logs but I get this output:
# Configure service as NodePort for local access
service:
type: NodePort
ports:
- name: http
port: 80
targetPort: 80
# Database connection details (for a local PostgreSQL database
database:
vendor: postgres
hostname: host.minikube.internal
port: 5432
database: nora
username: postgres
password: ""
# Optionally configure network policies and other settings for your local environment
networkPolicy:
enabled: false
My values.yaml file which I use to override the values.yaml in the repository of codecentric.
When I write: kubectl describe pods keycloakx-0 I get the following output in the terminal:
Events:
Type Reason Age From Message
Normal Scheduled 2m31s default-scheduler Successfully assigned default/keycloakx-0 to minikube
Normal Pulled 94s (x4 over 2m30s) kubelet Container image "quay.io/keycloak/keycloak:22.0.4" already present on machine
Normal Created 94s (x4 over 2m30s) kubelet Created container keycloak
Normal Started 94s (x4 over 2m30s) kubelet Started container keycloak
Warning BackOff 61s (x13 over 2m28s) kubelet Back-off restarting failed container keycloak in pod keycloakx-0_default(b7737a7e-074d-4522-8e65-f90187516d9c)
So the start of the container is not really working…
