Hello
I upgrade from 7.0.0 to 7.0.1 and have the stacktrace below
And when I switch back to 7.0.0, it works fine
15:22:23,228 INFO [org.jboss.as.clustering.infinispan] (ServerService Thread Pool -- 72) WFLYCLINF0002: Started authorizationRevisions cache from keycloak container
15:22:23,229 INFO [org.keycloak.connections.infinispan.DefaultInfinispanConnectionProviderFactory] (ServerService Thread Pool -- 72) Node name: keycloak-5dd89bd65-c2vw6, Site name: null
15:24:34,698 WARN [org.jboss.jca.core.connectionmanager.pool.strategy.OnePool] (ServerService Thread Pool -- 72) IJ000604: Throwable while attempting to get a new connection: null: javax.resource.ResourceException: IJ031084: Unable to create connection
at org.jboss.ironjacamar.jdbcadapters@1.4.16.Final//org.jboss.jca.adapters.jdbc.local.LocalManagedConnectionFactory.createLocalManagedConnection(LocalManagedConnectionFactory.java:345)
at org.jboss.ironjacamar.jdbcadapters@1.4.16.Final//org.jboss.jca.adapters.jdbc.local.LocalManagedConnectionFactory.getLocalManagedConnection(LocalManagedConnectionFactory.java:352)
at org.jboss.ironjacamar.jdbcadapters@1.4.16.Final//org.jboss.jca.adapters.jdbc.local.LocalManagedConnectionFactory.createManagedConnection(LocalManagedConnectionFactory.java:287)
at org.jboss.ironjacamar.impl@1.4.16.Final//org.jboss.jca.core.connectionmanager.pool.mcp.SemaphoreConcurrentLinkedDequeManagedConnectionPool.createConnectionEventListener(SemaphoreConcurrentLinkedDequeManagedConnectionPool.java:1325)
at org.jboss.ironjacamar.impl@1.4.16.Final//org.jboss.jca.core.connectionmanager.pool.mcp.SemaphoreConcurrentLinkedDequeManagedConnectionPool.getConnection(SemaphoreConcurrentLinkedDequeManagedConnectionPool.java:499)
at org.jboss.ironjacamar.impl@1.4.16.Final//org.jboss.jca.core.connectionmanager.pool.AbstractPool.getSimpleConnection(AbstractPool.java:632)
at org.jboss.ironjacamar.impl@1.4.16.Final//org.jboss.jca.core.connectionmanager.pool.AbstractPool.getConnection(AbstractPool.java:604)
at org.jboss.ironjacamar.impl@1.4.16.Final//org.jboss.jca.core.connectionmanager.AbstractConnectionManager.getManagedConnection(AbstractConnectionManager.java:624)
at org.jboss.ironjacamar.impl@1.4.16.Final//org.jboss.jca.core.connectionmanager.tx.TxConnectionManagerImpl.getManagedConnection(TxConnectionManagerImpl.java:440)
at org.jboss.ironjacamar.impl@1.4.16.Final//org.jboss.jca.core.connectionmanager.AbstractConnectionManager.allocateConnection(AbstractConnectionManager.java:789)
at org.jboss.ironjacamar.jdbcadapters@1.4.16.Final//org.jboss.jca.adapters.jdbc.WrapperDataSource.getConnection(WrapperDataSource.java:151)
at org.jboss.as.connector@17.0.1.Final//org.jboss.as.connector.subsystems.datasources.WildFlyDataSource.getConnection(WildFlyDataSource.java:64)
at org.keycloak.keycloak-model-jpa@7.0.1//org.keycloak.connections.jpa.DefaultJpaConnectionProviderFactory.getConnection(DefaultJpaConnectionProviderFactory.java:366)
at org.keycloak.keycloak-model-jpa@7.0.1//org.keycloak.connections.jpa.updater.liquibase.lock.LiquibaseDBLockProvider.lazyInit(LiquibaseDBLockProvider.java:65)
at org.keycloak.keycloak-model-jpa@7.0.1//org.keycloak.connections.jpa.updater.liquibase.lock.LiquibaseDBLockProvider.lambda$waitForLock$2(LiquibaseDBLockProvider.java:96)
at org.keycloak.keycloak-server-spi-private@7.0.1//org.keycloak.models.utils.KeycloakModelUtils.suspendJtaTransaction(KeycloakModelUtils.java:682)
at org.keycloak.keycloak-model-jpa@7.0.1//org.keycloak.connections.jpa.updater.liquibase.lock.LiquibaseDBLockProvider.waitForLock(LiquibaseDBLockProvider.java:94)
at org.keycloak.keycloak-services@7.0.1//org.keycloak.services.resources.KeycloakApplication$1.run(KeycloakApplication.java:144)
at org.keycloak.keycloak-server-spi-private@7.0.1//org.keycloak.models.utils.KeycloakModelUtils.runJobInTransaction(KeycloakModelUtils.java:227)
at org.keycloak.keycloak-services@7.0.1//org.keycloak.services.resources.KeycloakApplication.<init>(KeycloakApplication.java:137)
at org.jboss.resteasy.resteasy-jaxrs@3.7.0.Final//org.jboss.resteasy.core.ConstructorInjectorImpl.construct(ConstructorInjectorImpl.java:152)
at org.jboss.resteasy.resteasy-jaxrs@3.7.0.Final//org.jboss.resteasy.spi.ResteasyProviderFactory.createProviderInstance(ResteasyProviderFactory.java:2784)
at org.jboss.resteasy.resteasy-jaxrs@3.7.0.Final//org.jboss.resteasy.spi.ResteasyDeployment.createApplication(ResteasyDeployment.java:364)
at org.jboss.resteasy.resteasy-jaxrs@3.7.0.Final//org.jboss.resteasy.spi.ResteasyDeployment.startInternal(ResteasyDeployment.java:277)
at org.jboss.resteasy.resteasy-jaxrs@3.7.0.Final//org.jboss.resteasy.spi.ResteasyDeployment.start(ResteasyDeployment.java:89)
at org.jboss.resteasy.resteasy-jaxrs@3.7.0.Final//org.jboss.resteasy.plugins.server.servlet.ServletContainerDispatcher.init(ServletContainerDispatcher.java:119)
at org.jboss.resteasy.resteasy-jaxrs@3.7.0.Final//org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.init(HttpServletDispatcher.java:36)
at io.undertow.servlet@2.0.21.Final//io.undertow.servlet.core.LifecyleInterceptorInvocation.proceed(LifecyleInterceptorInvocation.java:117)
at org.wildfly.extension.undertow@17.0.1.Final//org.wildfly.extension.undertow.security.RunAsLifecycleInterceptor.init(RunAsLifecycleInterceptor.java:78)
at io.undertow.servlet@2.0.21.Final//io.undertow.servlet.core.LifecyleInterceptorInvocation.proceed(LifecyleInterceptorInvocation.java:103)
at io.undertow.servlet@2.0.21.Final//io.undertow.servlet.core.ManagedServlet$DefaultInstanceStrategy.start(ManagedServlet.java:303)
at io.undertow.servlet@2.0.21.Final//io.undertow.servlet.core.ManagedServlet.createServlet(ManagedServlet.java:143)
at io.undertow.servlet@2.0.21.Final//io.undertow.servlet.core.DeploymentManagerImpl$2.call(DeploymentManagerImpl.java:583)
at io.undertow.servlet@2.0.21.Final//io.undertow.servlet.core.DeploymentManagerImpl$2.call(DeploymentManagerImpl.java:554)
at io.undertow.servlet@2.0.21.Final//io.undertow.servlet.core.ServletRequestContextThreadSetupAction$1.call(ServletRequestContextThreadSetupAction.java:42)
at io.undertow.servlet@2.0.21.Final//io.undertow.servlet.core.ContextClassLoaderSetupAction$1.call(ContextClassLoaderSetupAction.java:43)
at org.wildfly.extension.undertow@17.0.1.Final//org.wildfly.extension.undertow.security.SecurityContextThreadSetupAction.lambda$create$0(SecurityContextThreadSetupAction.java:105)
at org.wildfly.extension.undertow@17.0.1.Final//org.wildfly.extension.undertow.deployment.UndertowDeploymentInfoService$UndertowThreadSetupAction.lambda$create$0(UndertowDeploymentInfoService.java:1502)
at io.undertow.servlet@2.0.21.Final//io.undertow.servlet.core.DeploymentManagerImpl.start(DeploymentManagerImpl.java:596)
at org.wildfly.extension.undertow@17.0.1.Final//org.wildfly.extension.undertow.deployment.UndertowDeploymentService.startContext(UndertowDeploymentService.java:97)
at org.wildfly.extension.undertow@17.0.1.Final//org.wildfly.extension.undertow.deployment.UndertowDeploymentService$1.run(UndertowDeploymentService.java:78)
at org.jboss.threads@2.3.3.Final//org.jboss.threads.JBossThread.run(JBossThread.java:485)
Caused by: com.mysql.jdbc.exceptions.jdbc4.CommunicationsException: Communications link failure
The last packet sent successfully to the server was 0 milliseconds ago. The driver has not received any packets from the server.
at com.mysql.jdbc@5.1.46//com.mysql.jdbc.Util.handleNewInstance(Util.java:425)
at com.mysql.jdbc@5.1.46//com.mysql.jdbc.SQLError.createCommunicationsException(SQLError.java:990)
at com.mysql.jdbc@5.1.46//com.mysql.jdbc.MysqlIO.<init>(MysqlIO.java:342)
at com.mysql.jdbc@5.1.46//com.mysql.jdbc.ConnectionImpl.coreConnect(ConnectionImpl.java:2188)
at com.mysql.jdbc@5.1.46//com.mysql.jdbc.ConnectionImpl.connectOneTryOnly(ConnectionImpl.java:2221)
at com.mysql.jdbc@5.1.46//com.mysql.jdbc.ConnectionImpl.createNewIO(ConnectionImpl.java:2016)
at com.mysql.jdbc@5.1.46//com.mysql.jdbc.ConnectionImpl.<init>(ConnectionImpl.java:776)
at com.mysql.jdbc@5.1.46//com.mysql.jdbc.JDBC4Connection.<init>(JDBC4Connection.java:47)
at com.mysql.jdbc@5.1.46//com.mysql.jdbc.ConnectionImpl.getInstance(ConnectionImpl.java:386)
at com.mysql.jdbc@5.1.46//com.mysql.jdbc.NonRegisteringDriver.connect(NonRegisteringDriver.java:330)
at org.jboss.ironjacamar.jdbcadapters@1.4.16.Final//org.jboss.jca.adapters.jdbc.local.LocalManagedConnectionFactory.createLocalManagedConnection(LocalManagedConnectionFactory.java:321)
... 55 more
Caused by: java.net.ConnectException: Connection timed out (Connection timed out)
at java.base/java.net.PlainSocketImpl.socketConnect(Native Method)
at java.base/java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:399)
at java.base/java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:242)
at java.base/java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:224)
at java.base/java.net.SocksSocketImpl.connect(SocksSocketImpl.java:403)
at java.base/java.net.Socket.connect(Socket.java:609)
at com.mysql.jdbc@5.1.46//com.mysql.jdbc.StandardSocketFactory.connect(StandardSocketFactory.java:211)
at com.mysql.jdbc@5.1.46//com.mysql.jdbc.MysqlIO.<init>(MysqlIO.java:301)
... 68 more
15:24:34,718 ERROR [org.jboss.msc.service.fail] (ServerService Thread Pool -- 72) MSC000001: Failed to start service jboss.deployment.unit."keycloak-server.war".undertow-deployment: org.jboss.msc.service.StartException in service jboss.deployment.unit."keycloak-server.war".undertow-deployment: java.lang.RuntimeException: RESTEASY003325: Failed to construct public org.keycloak.services.resources.KeycloakApplication(javax.servlet.ServletContext,org.jboss.resteasy.core.Dispatcher)
at org.wildfly.extension.undertow@17.0.1.Final//org.wildfly.extension.undertow.deployment.UndertowDeploymentService$1.run(UndertowDeploymentService.java:81)
Caused by: java.lang.RuntimeException: RESTEASY003325: Failed to construct public org.keycloak.services.resources.KeycloakApplication(javax.servlet.ServletContext,org.jboss.resteasy.core.Dispatcher)
at org.jboss.resteasy.resteasy-jaxrs@3.7.0.Final//org.jboss.resteasy.core.ConstructorInjectorImpl.construct(ConstructorInjectorImpl.java:164)
... 8 more
Caused by: java.lang.RuntimeException: Failed to connect to database
at org.keycloak.keycloak-model-jpa@7.0.1//org.keycloak.connections.jpa.DefaultJpaConnectionProviderFactory.getConnection(DefaultJpaConnectionProviderFactory.java:372)
... 31 more
Caused by: java.sql.SQLException: javax.resource.ResourceException: IJ000453: Unable to get managed connection for java:jboss/datasources/KeycloakDS
at org.jboss.ironjacamar.jdbcadapters@1.4.16.Final//org.jboss.jca.adapters.jdbc.WrapperDataSource.getConnection(WrapperDataSource.java:159)
... 43 more
Caused by: javax.resource.ResourceException: IJ000453: Unable to get managed connection for java:jboss/datasources/KeycloakDS
at org.jboss.ironjacamar.impl@1.4.16.Final//org.jboss.jca.core.connectionmanager.AbstractConnectionManager.getManagedConnection(AbstractConnectionManager.java:690)
... 45 more
Caused by: javax.resource.ResourceException: IJ031084: Unable to create connection
... 48 more
... 55 more
... 68 more
15:24:34,733 ERROR [org.jboss.as.controller.management-operation] (Controller Boot Thread) WFLYCTL0013: Operation ("add") failed - address: ([("deployment" => "keycloak-server.war")]) - failure description: {"WFLYCTL0080: Failed services" => {"jboss.deployment.unit.\"keycloak-server.war\".undertow-deployment" => "java.lang.RuntimeException: RESTEASY003325: Failed to construct public org.keycloak.services.resources.KeycloakApplication(javax.servlet.ServletContext,org.jboss.resteasy.core.Dispatcher)
Caused by: java.net.ConnectException: Connection timed out (Connection timed out)"}}
15:24:34,823 INFO [org.jboss.as.server] (Thread-1) WFLYSRV0220: Server shutdown has been requested via an OS signal
15:24:34,875 INFO [org.jboss.as.connector.subsystems.datasources] (MSC service thread 1-2) WFLYJCA0010: Unbound data source [java:jboss/datasources/KeycloakDS]
15:24:34,876 INFO [org.jboss.modcluster] (ServerService Thread Pool -- 77) MODCLUSTER000002: Initiating mod_cluster shutdown
Notice I run Keycloak in Kubernates and have this deployment yaml
apiVersion: apps/v1
kind: Deployment
metadata:
namespace: default
labels:
app: keycloak
spec:
replicas: 1
selector:
matchLabels:
app: keycloak
template:
metadata:
labels:
app: keycloak
annotations:
restart: "0"
spec:
containers:
- name: keycloak
image: jboss/keycloak
env:
- name: KEYCLOAK_USER
value: admin
- name: KEYCLOAK_PASSWORD
value: abcd
value: "true"
- name: KEYCLOAK_LOGLEVEL
value: INFO
- name: DB_VENDOR
value: mysql
- name: DB_ADDR
value: a.eu-west-1.rds.amazonaws.com/keycloak:7.0.1
- name: DB_PORT
value: "3306"
- name: DB_USER
value: keycloak
- name: DB_PASSWORD
value: abc123
- name: JDBC_PARAMS
value: character_set_server=utf8mb4&useUnicode=true&verifyServerCertificate=false&useSSL=true&requireSSL=true&allowPublicKeyRetrieval=true&serverTimezone=Europe/Paris
ports:
- name: http
containerPort: 8080
- name: https
containerPort: 8443
readinessProbe:
httpGet:
path: /auth/realms/master
port: 8080
Have you an idea ?
