Hello all,
I just wanted to make a litle anouncement informing you that Keycloakify 10 have finally been realased.
Keycloakify is a framework for creating Keycloak themes.
This release is a major overhaul, featuring a near-complete rewrite. Here’s a brief overview of the key updates:
- Full Page Support: All pages are now fully supported, with React components that align with the latest default Keycloak theme. Explore Pages
- Revamped Documentation: The documentation website has been completely redesigned and now includes multiple video tutorials for easier learning. Visit Documentation
- Enhanced Compatibility: Supports Keycloak 24 and 25 with full feature parity with the default theme. Anything that works in the default theme works seamlessly in Keycloakify.
- Real-Time Password Validation: Password validation now happens in real-time, adhering to the password policies set on the Keycloak server. Learn More
- Easy Theme Testing: Introducing the
npx keycloakify start-keycloak
command, allowing you to test your theme in a preconfigured Keycloak container. See Documentation - SPA Account Theme Support: Single Page Application (SPA) support for the Account theme (v3). Learn More
- No Dependencies: Keycloakify is now self contained. It won’t installs a ton of dependencies in your node_modules like the previous version did.
- Localized Messages: Messages defined on the realm in the Keycloak Admin Console are now accessible on the client side. Learn More
- Terms and Conditions: The terms and conditions functionality now works just as it does in the default Keycloak theme. Learn More
- Customizable kcContext Exclusions: You can now specify values to be excluded from the
kcContext
. Learn More - Post-Build Transformations: Apply transformations before the theme is generated. Learn More
One more thing I’d like to add is that now Keycloakify is no longer just a React solution.
You can use React if you want to use your own components or fancy libraries like MUI or Shadcn/ui but it’s not mandatory.
But you can also customize the pages without touching React using CSS, SCSS, Tailwind, Bootstrap, @emotion/css, you name it.
There is even a starter for Angular now, but I don’t advertise it to much yet since the author is still working on it.
